Local Time 03:32 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Constants in an include file
elk1984
Posted: 11:04pm 12 Sep 2020
Very newbie question (sorry!), but I can't find a way to keep my contants declared outside the main body of my code.
I've tried putting them in a SUB (not found as they're declared local) and in an include file (no effect).
Is this possible?
Thanks in advance for any help.
elk1984
Posted: 12:08am 13 Sep 2020
  elk1984 said  Hi,
Is this possible?
Solved my own issue.  Two things I'd done wrong.
1. When trying to include my constants, I'd used
 #Include "Constants.lib"
Having two leading spaces meant the #Include directive was ignored.
2. When I removed the leading spaces, I got an error saying the file must be a .inc file
Renaming my .lib to .inc and the constants are working like a charm!
mkopack73
Posted: 01:53pm 13 Sep 2020
Interesting that the 2 leading spaces caused it not to work. Let Peter know. Might be something he can fix quickly (might not be, probably some annoying quirk of the parser...)
Posted: 01:58pm 13 Sep 2020
  Quote  Interesting that the 2 leading spaces caused it not to work. Let Peter know.
Fixed in V5.05.05
elk1984
Posted: 02:52pm 13 Sep 2020
Fixed in V5.05.05
Thanks - now I've got a long enough data cable, I'll flash the firmware tonight.  I'm liking the flexibility hooking the CMM2 up over serial is giving.  One keyboard and the ability to send files without spending £100 on a Wireless SD Card (although that would be cool)
Womble
Posted: 07:26pm 18 Sep 2020
  elk1984 said  ... without spending £100 on a Wireless SD Card (although that would be cool)
Don't do it.  Wireless SD cards DO NOT WORK in the CMM2.
Someone has already tried, and failed.
elk1984
Posted: 09:21am 19 Sep 2020
Thanks for the tip. That's £100 to spend on other gadgets. Like a video capture card
Edited 2020-09-19 19:23 by elk1984
