Local Time 05:37 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ' Hardware ' random number generators
hitsware2
Posted: 03:07pm 10 Sep 2020
For the random number seed, a spare floating analog input is handy.
spare = 23 ' any spare analog pin left floating.
setpin spare, ain
RANDOMIZE pin(spare)*1000
print rnd()
Yes !
That explains why the same ( newer )
chips with ' hardware random number generators '
are the ones with analog inputs !
my site
MustardMan
Posted: 11:25pm 10 Sep 2020
Quite possibly!
There are more sophisticated ways of doing it, and depending on needs (ie: do you want a completely random sequence, or is a random seed to a PRNG enough). Doing an ADC on an input is quite slow and very suitable for the latter, but if you want lots of numbers and want them quickly, some dedicated hardware is best.
Cheers,
goc30
Posted: 12:59am 11 Sep 2020
when i was younger i had written a random number generation function based on an RC circuit. The principle was based on the instability of the circuit in time. With very average components, the value of time base is fixed, but it can changes between 2 values, for example if you have an RC for 50ms, this value change from 49 to 51ms (temp, hum, old components, etc..). It was then enough to count the duration of the pulse, in µsec, to have a number which varies from 1 to x, randomly.
Edited 2020-09-11 11:04 by goc30
hitsware2
Posted: 02:42am 11 Sep 2020
BTW .... Original quote & code from Tassy Jim
I cant imagine how an algorithm could be unpredictable .
Leaving only analog ( if only for the ' seed ' )
as the only means .
Though the sensing could be something besides voltage .
I . E ... solar cell or geiger counter .
my site
JoOngle
Posted: 03:11am 11 Sep 2020
Or, you can use a noisy Germanium diode with some extra components, like a transistor to amplify the signal somewhere between 0-5v (with a 3.3v converter) and a schmitt trigger perhaps?
Should be quite random, as the noisy Germanium diode can generate white noise when abused properly ;)
Posted: 07:03am 11 Sep 2020
I played with this a while back. This goes into explaining how/why a TRNG seed can be quite effective as a starting place for PRNG with some very good resources cited in the article.
http://www.fruitoftheshed.com/Circuit%20Ideas.Random-Bit-Generator-for-cryptographic-strength-random-numbers.ashx
and the code for it
http://www.fruitoftheshed.com/MMBasic.True-Random-Generator-companion-code-for-circuit.ashx
hitsware2
Posted: 08:49am 11 Sep 2020
  goc30 said  when i was younger i had written a random number generation function based on an RC circuit. The principle was based on the instability of the circuit in time. With very average components, the value of time base is fixed, but it can changes between 2 values, for example if you have an RC for 50ms, this value change from 49 to 51ms (temp, hum, old components, etc..). It was then enough to count the duration of the pulse, in µsec, to have a number which varies from 1 to x, randomly.
Good one !
Hadn't heard of that approach .
my site
BrianP
Posted: 10:39pm 11 Sep 2020
I was told that there is an entity in the US of A that uses the camera image of a wall of lava lamps for their RNG seed
Should be enough entropy?
B
