Local Time 06:26 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit printing
Herry
Posted: 08:50pm 30 Aug 2020
Hello all
Is there a way to increase the size of the font for *printing out* files in MMEDIT.
Senior?!  Whatever it says, I'm a complete and utter beginner...
Posted: 08:56pm 30 Aug 2020
No sorry,
It is fixed at Courier New 8 point.
Any bigger and there would be too much line-wrap.
If you want to change the size, use "Save as RTF" and change it in your preferred word processor. That way you have full colour and full control over the layout.
Chopperp
Posted: 10:44pm 30 Aug 2020
Hi Jim
I did an RTF yesterday for the first time for ages & there was no UPPER case for keywords. Has it always been like that?
Just asking.
Brian
ChopperP
Posted: 11:01pm 30 Aug 2020
  Chopperp said  Hi Jim
Just asking.
Brian
Try
Program/Save keyword CASE
There is a difference between displaying keywords in upper case and changing them in the text.
The keyword case is not saved with the text unless forced.
Doing it all the time slows things down too much.
Chopperp
Posted: 12:19am 31 Aug 2020
Thanks Jim, that worked.
BTW, you made a comment recently that your brother was a much better programmer than you.
He must be really, really good.
Your work on TBS is much appreciated by all.
Brian
ChopperP
Posted: 07:59am 31 Aug 2020
TOTALLY agree with that, Brian!
The entire MM platform and series of chips would not be as enjoyable to program, if not for the fantastic MMEDIT.
The built-in editor is awesome for squishing bugs, and then you can copy the fix back across to MMEDIT for the master code, once you have proved that you have indeed squished those nasty bugs.
Posted: 01:18pm 31 Aug 2020
I totally agree (when I can lay my hands on a Windows machine at work)...
To bad my home computers are all linux.
So I use the build in editor a lot.
That is also why I was not hesitant to look if I can get geany working for the micromites. It would serve me well for myself also. But haven't done any try yet.
I am just too lazy I guess.
Edited 2020-08-31 23:21 by Volhout
Posted: 07:20am 01 Sep 2020
Does MMEdit work under WINE / any chance to get MMEdit working under WINE?
Posted: 09:29pm 01 Sep 2020
  JohnS said  Does MMEdit work under WINE / any chance to get MMEdit working under WINE?
Yes
