Local Time 08:28 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display mode frame rates
capsikin
Posted: 12:57am 24 Aug 2020
  Atomizer_Zero said  Whoops. Thats what I meant lol. sorry. Been looking at numbers for hours and hours at this point.
right now, the ppu is bottlenecking the cpu pretty hard. obviously the ppu has a lot to do. it does ~340 cycles per scanline, with 262 scanlines per frame. so, for 60 frames per second, its 15,720 scanlines, 5,344,800 ppu cycles. So, with the cpu doing 1,790,000 cycles and the ppu doing 5,344,800 cycles... it's a lot to do in a per second.
I had also assumed 60 frames per second - I think it would be good for retro stuff - but I don't think that's the default frame rate.
What frame rate are the various modes, and is it possible for the program to set 60 fps if it's not the default?
(I was just using your post as a prompt for mine, you may be going to run the emulation at 60fps even if the display output is different)
Edited 2020-08-24 11:00 by capsikin
Sasquatch
Posted: 01:41am 24 Aug 2020
According to my monitor, Modes 1 and 9 are 60Hz, All other Modes are 75Hz.  Keep in mind that this is the video frame rate that the hardware is sending to the VGA monitor.  The actual rate for updating the displayed image is software controlled.
-Carl
berighteous
Posted: 01:59am 24 Aug 2020
if you change your screen every 1/10 second, you're at 10fps regardless of your refresh rate.
capsikin
Posted: 06:52am 24 Aug 2020
  Sasquatch said  According to my monitor, Modes 1 and 9 are 60Hz, All other Modes are 75Hz.  Keep in mind that this is the video frame rate that the hardware is sending to the VGA monitor.  The actual rate for updating the displayed image is software controlled.
Thanks.
  berighteous said  if you change your screen every 1/10 second, you're at 10fps regardless of your refresh rate.
Kind of, but it won't be an even 10 fps.
Doing 60Hz game updates on a 75Hz screen connection would lose the smoothness of motion you could otherwise get with a 60 or 75Hz frame rate.
Posted: 10:14am 24 Aug 2020
i am a little surprised that some modes operate at 75Hz frame rate, my understanding was that many years ago the world had settled on 60Hz. i could see some monitors, both new and old, being unhappy with 75Hz, and indeed did recently strike a monitor that was extremely unhappy with a 75Hz output from a DELL pc via the VGA port. in that case a different monitor attached to one of the DisplayPort outputs worked fine.
peter/geoff:
is there anywhere a list of ALL modes available on the CMM2, along with:
1. their on-screen resolution
2. their actual resolution (ignoring doubled-up dots or lines)
3. the colour depth
4. the frame rate that the CMM2 uses,
5. other timing information.
if it is so, is there any good reason why a 75Hz (or any other than 60Hz) frame rate is used?
rob   :-)
Posted: 01:06pm 24 Aug 2020
  robert.rozee said  . . . i could see some monitors, both new and old, being unhappy with 75Hz, and indeed did recently strike a monitor that was extremely unhappy with a 75Hz output
My ancient Polaroid monitor flm1511 doesn't handle 75Hz.
mclout999
Posted: 04:04pm 24 Aug 2020
Am I wrong or are people confuing frame rate with REFRESH RATE.  Frame rate is a the number of frams you program is able to update during run time(depens on the workload of the procesor).  The refresh rate of the mode is just the rate at witch the video circutry is refreshing the immages provided to it by the device.  This dose not effect the nuber of frams per second but it does effect the smoothness of the output.  In PC FPS gaming a monitores refresh rate is all important as the motion on screen can get very blury and have motion tear effects at lower refresh rates.  I spend a lot of money to have at least 120Hz to make fast moveing graphics that don't look like crap. Other have hit on it but I hope this help to clearify it. Tell me if I got this right or not.
capsikin
Posted: 04:07pm 24 Aug 2020
  mclout999 said  Am I wrong or are people confuing frame rate with REFRESH RATE.  Frame rate is a the number of frams you program is able to update during run time(depens on the workload of the procesor).  The refresh rate of the mode is just the rate at witch the video circutry is refreshing the immages provided to it by the device.  This dose not effect the nuber of frams per second but it does effect the smoothness of the output.  In PC FPS gaming a monitores refresh rate is all important as the motion on screen can get very blury and have motion tear effects at lower refresh rates.  I spend a lot of money to have at least 120Hz to make fast moveing graphics that don't look like crap. Other have hit on it but I hope this help to clearify it. Tell me if I got this right or not.
I may have used the wrong term, refresh rate is what I was mostly talking about (though also matching frame rate to refresh rate).
Posted: 04:33pm 24 Aug 2020
ditto - i was referring to "frame rate" in the classic video sense (pre-computers): where a frame consists of two interlaced fields, and the NTSC/american frame rate is 30Hz, while for PAL/european it is 25Hz. as far as i am aware, LCD computer monitors have generally settled universally to 60Hz (non-interlaced) for most of this century (irrespective of country), with 120Hz starting to appear in the last few years for some high-end equipment.
a variety of different frame rates (and a mixture of interlaced and non-interlaced) were necessary back in the days of CRT monitors, where the electron beam that 'drew' the picture was moved magnetically by coils that could only have very limited ranges of frequencies fed into them. with LCDs, this constraint (formerly imposed by the magnetic components) no longer exists, but has been replaced with other limitations (including cost-reduction) that have seen 60Hz emerge as the 'standard' frame rate.
i guess a less confusing term would be to talk about the vertical sync rate, which would also be 60Hz.
rob   :-)
Edited 2020-08-25 02:35 by robert.rozee
capsikin
Posted: 12:25am 25 Aug 2020
  robert.rozee said  ditto - i was referring to "frame rate" in the classic video sense (pre-computers): where a frame consists of two interlaced fields, and the NTSC/american frame rate is 30Hz, while for PAL/european it is 25Hz. as far as i am aware, LCD computer monitors have generally settled universally to 60Hz (non-interlaced) for most of this century (irrespective of country), with 120Hz starting to appear in the last few years for some high-end equipment.
rob   :-)
Would they also support lower frame rates? VGA and HDMI both support lower frame rates as well as higher. Unfortunately VGA 50Hz support doesn't look like it's standard though.
  robert.rozee said  is there anywhere a list of ALL modes available on the CMM2, along with:
3. the colour depth
I found "Graphics Programming on the CMM2" has quite a bit of information on the older resolutions (mode resolutions 1-5). I haven't seen the info for the modes in the new betas compiled into a list, and I don't remember how much info was in the beta announcements. Colour depth would have the same options as the old modes. (8, 16 or 12 bits, with 12 bits having an alpha channel and 2 pages used as layers).
panky
Posted: 12:33am 25 Aug 2020
Peter is still doing quite a bit of developement in the MODE area so I am waiting a bit for the dust to settle and with Peter's help/approval, will update all the new MODE features that have appeared in recent betas.
Doug.
capsikin
Posted: 08:16am 25 Aug 2020
I was mistaken about the colour depth always having the same options.
From https://www.thebackshed.com/forum/ViewTopic.php?TID=12438&P=5#153217
"[mode] 9 = 1024x768 (NB: 12-bit colour depth not available in this mode)"
Other info from the thread:
New modes
7 = 320x240
8 = 640x480
New mode 6, 256x240 for easier porting of NES games
Posted: 12:44pm 25 Aug 2020
bear in mind, i don't have a CMM2. my interest is purely academic.
for each mode, i take it there are up to three variations: 8-bit, 12-bit, and 16-bits. not all modes support all three. between 8/12/16 there may be timing differences, as different quantities of data is being shuffled around - although if there is a lookup table involved, this may negate the differences.
some/several of the lower resolution modes double up pixels and/or lines, yes? so they are effectively a quite different resolution to that observed on-screen.
what i am interested in is the timing set (including front and back porches) for each of the mode and colour depth combinations, in part to look at what the resulting dot-clock is. i am curious about the shimmering some see, the cure for the problem (a crystal block), and that some monitors seem quite unhappy with some modes, while others have displacements that can not be adjusted out.
rob   :-)
Posted: 01:04pm 25 Aug 2020
Not sure why we need to keep repeating this. There are three resolutions used
640x480 @ 75Hz, 800x600@60Hz and 1024x768@60Hz.
See here for the full details. All modes other than 1 and 9 use 640x480 and the  timings are exactly as per the reference in all cases
Posted: 03:01pm 25 Aug 2020
I think modes are:
       1 = 800x600
       2 = 640x400
       3 = 320x200
       4 = 480x432
       5 = 240x216
       6 = 256x240
       7 = 320x240
       8 = 640x480
Posted: 06:35pm 25 Aug 2020
peter, john: much appreciate the info.
may i ask why 75Hz is used for modes based around 640x480?
rob   :-)
Posted: 06:42pm 25 Aug 2020
  Quote  why 75Hz is used for modes based around 640x480?
More stable - less shimmer of flicker. Freq can be produced precisely
Posted: 09:22pm 25 Aug 2020
And while 60Hz was around in the early days, it is not VESA compliant and would be likely to cause more compatibility problems than it solved.
MikoKisai
Posted: 10:05pm 25 Aug 2020
Are you sure about that? I find this rather curious, because according to their specifications, neither of my monitors support 640x480@75... only 640x480@60. It's also listed as an "industry standard" on the timing page that Peter linked to, which isn't the case on any of the other modes.
(It may be the case that they do support it in practice - but I don't have my CMM2 yet to test.)
I also see 640x480@60 listed in a copy I found of the VESA monitor timing standards, suggesting that it would be commonly expected to work.
Edited 2020-08-26 08:19 by MikoKisai
Posted: 10:21pm 25 Aug 2020
I used this as a reference:
"VESA and Industry Standards and Guidelines
for Computer Display Monitor Timing (DMT)
Version 1.0, Rev. 12
November 17, 2008"
It lists 640x480 60Hz as
  Quote  Adopted: n/a ** For Reference Only - Not a VESA Standard **
Resolution: 640 x 480 at 60 Hz (non-interlaced)
Either way 75Hz is a standard and any modern monitor should be able to display it.
