Local Time 09:40 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 / MMBasic equivalent to Python dictionary
Nimue
Posted: 11:44am 23 Aug 2020
Hi all
I am trying to port a Python script to MMBasic (on CMM2).
I use dictionaries to simulate a game of snakes and ladders:
Board_Layout = {2:16,7:21,22:11,24:35,30:43,31:28,33:17,53:69,58:41,62:98}
with the pairs of numbers representing the start / end of a snake or ladder.
So for example, 2:16 -- means if the player ends on square 2, this then returns 16 (ie a ladder).
position = position + dice
The players position is given by: position = Board_Layout.get(position, position), which finds position in the dictionary and returns the value from the pair.  If not found, position is just position -- ie the value just calculated.
My questions are:
How to do replicate the Board_layout ={} dictionary function?
How to I then replicate the .get method?
Any pointers greatly recieved.
Nim
Nimue
Posted: 11:51am 23 Aug 2020
Update 1
So I figure I can do this with a series of Case / Select statements   --  imagine that would work fine.
But that seems clumbersome as each pair would need to be a CASE = line...
I'll see how far I get with that and post the code (minus the visualisation which uses Matplotlib library).
Nim
realmnm
Posted: 12:49pm 23 Aug 2020
Maybe set it up as an array, where the index is the square number, and the value is the square to go to. If it  doesn’t go anywhere, the value is the same as the index.
Martin
This signature intentionally left blank.
Nimue
Posted: 12:52pm 23 Aug 2020
  realmnm said  Maybe set it up as an array, where the index is the square number, and the value is the square to go to. If it  doesn’t go anywhere, the value is the same as the index.
Martin
I'll have a look at that...
Here is the code using CASE / SELECT
Const DICE_SIZE = 6   ' number of faces on dice
Const NUM_GAMES = 100  ' how many games to simualte
Function position(x)
Select Case x
   Case 2
       position = 16
   Case 7
       position = 21
   Case 22
       position = 11
   Case 24
       position = 35
   Case 30
       position = 43
   Case 31
       position = 28
   Case 33
       position = 17
   Case 53
       position = 69
   Case 58
       position = 41
   Case 62
       position = 98
   Case 64
       position = 16
   Case 67
       position = 50
   Case 73
       position = 92
   Case 87
       position = 95
   Case 93
       position = 74
   Case 99
       position = 85
   Case Else
       position = x
End Select
End Function
'Print position(67)
Sub play_game()
   x = 0
   turns = 0
    Do While  x < 100
       turns = turns + 1
      'Print turns;
       roll = Int((Rnd()*DICE_SIZE)+1)
       'Print roll
       If x + roll > 100 Then Exit Sub
       x = x + roll
       x = position(x)
For y = 1 To NUM_GAMES
   play_game()
   game_total=game_total+turns
Next y
Print "Average number of turns, calculated over " NUM_GAMES " games = ",Int(game_total/NUM_GAMES)
Would have liked to use MATH - but it looks like this is not on the PC version of MMBasic.  When I push this to the CMM2, I will implement the MATH function.
Nim
Nimue
Posted: 01:27pm 23 Aug 2020
Martin
Here we go as an array:
Dim GAMES(NUM_GAMES)
GAMES(2)=16
GAMES(7)=21
GAMES(22)=11
GAMES(24)=35
GAMES(30)=43
GAMES(31)=28
GAMES(33)=17
GAMES(53)=69
GAMES(58)=41
GAMES(62)=98
GAMES(64)=16
GAMES(67)=50
GAMES(73)=92
GAMES(87)=96
GAMES(93)=74
GAMES(99)=85
position=GAMES(x)
If GAMES(x) = 0 Then position = x
End Function
Print position(19)
Sub play_game()
   x = 0
   turns = 0
    Do While  x < 100
       turns = turns + 1
      'Print turns;
       'Print roll
       x = x + roll
       x = position(x)
   play_game()
Next y
I assume this is more efficient as there is only one comparison inside the function this time.
Nice.
Really enjoying breaking things back to a "simpler" language and not relying on the Python stuff I take for granted.
Nim
