Forum Index : Microcontroller and PC projects : CMM2: Extend file read/write functions to work with terminal in/out ?
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4406 |
Would it be a good idea / possible to have LINE INPUT #nbr, PRINT #nbr and all their friends work with #nbr = 0 meaning read / write from the terminal ? i.e. the same as vanilla LINE INPUT and PRINT. This would be convenient and avoid an IF statement or two when writing programs where reading/writing both to files or the terminal are valid. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12093 |
Have you tried it? |
Obviously not or I would have found out it already works ![]() Proof, if it were needed, that I spend too much time on the forum and not enough time on the CMM2 ... or my day job for that matter. Cheers, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
