Local Time 10:46 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PLAY SOUND ..... Difference between " both " and " left and right " ?
hitsware2
Posted: 01:49am 18 Aug 2020
'Listen
do
for x= 0 to 1
select case x
case 0
for y=0 to 7
play sound 1,b,s,200,10
pause 100
play sound 1,b,s,200,0
pause 500
print "both": next y
case 1
for y=0 to 7
play sound 1,l,s,200,10
play sound 1,r,s,200,10
pause 100
play sound 1,l,s,200,0
play sound 1,r,s,200,0
pause 500
print "left and right": next y
end select
next x
loop
my site
Posted: 04:54am 18 Aug 2020
I think this is what you are getting at.
Setting both channels to 10 gives equal output.
Setting one channel to 10 with the second channel still off gives the correct level for that channel.
Setting one channel on but zero level gives zero output as expected
BUT
if you then set the second channel to 10, it's output is as expected 320mV and the other channel that should remain off has 790mV output.
DO
PLAY sound 1,B,O,200,0
PLAY sound 1,B,s,200,10 ' both channels 320mV
PRINT "both"
DO:LOOP UNTIL INKEY$ <> ""
PLAY STOP
'play sound 1,L,s,200,0
PLAY sound 1,R,s,200,10 ' right 320mV, left zero
PRINT "right"
PLAY STOP
PLAY sound 1,R,s,200,0  ' both channels zero
PAUSE 2000
PLAY sound 1,L,s,200,10 ' right 790mV, left 320mV
PRINT "left"
PLAY STOP
LOOP
hitsware2
Posted: 02:15pm 18 Aug 2020
> If you then set the second channel to 10,
Yes. I think we're on the same page .
Aurally ( using 'both' ( my snippet ) )
there is the expected series of short
duration tones.
BUT
Using 'L + R' there is one long tone
( as long as 8 pulses )
AND
It even seems to change notes !
( maybe up an octave ? )
my site
Posted: 02:28pm 18 Aug 2020
Found the problem - will be fixed in V5.05.05b11
hitsware2
Posted: 03:57pm 18 Aug 2020
  matherp said  Found the problem - will be fixed in V5.05.05b11
I'll dance at your wedding ! ....
Would you give a (simple as possible) explanation ?
my site
