Local Time 10:48 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM not holding time
Herry
Posted: 02:00am 17 Aug 2020
I wonder why?
Using syntax TIME$ = "HH:MM". It holds but after power off it is lost. Yes battery is in.
Senior?!  Whatever it says, I'm a complete and utter beginner...
Posted: 02:08am 17 Aug 2020
Did you remove the jumpers on the Waveshare module?
What do you get with
> print pin("BAT")
It should be close to " 3.02"
Herry
Posted: 02:36am 17 Aug 2020
Yes I did. the answer is 2.96...
Posted: 02:50am 17 Aug 2020
Have you set the date as well?
What do you get on the status line (lower right of screen)?
Herry
Posted: 03:26am 17 Aug 2020
haven't set date yet.
Posted: 06:26am 17 Aug 2020
  Herry said  haven't set date yet.
That was a hint to set the date if you haven't done so.
Part of the startup checks the year and if it is before 2018, the system assumes that the RTC is not set.
Herry
Posted: 08:35pm 17 Aug 2020
That [have you set the date] was a hint to set the date if you haven't done so.
And that was it! All OK now. Incidentally, I couldn't find any reference to that in the manual. Maybe I did not look  (or Ctrl-F) hard enough!
ZXKIM81
Posted: 06:41pm 19 Aug 2020
been playing on max-e-man and i love it
