Local Time 11:38 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Roll your own data logger - CMM2
Nimue
Posted: 09:12pm 10 Aug 2020
Good morning / evening -- depending on which side of the water you are on.
Firstly, I am in love with CMM2.  There, I said it.
Secondly, as a teacher adviser in Wales, the CMM2 is ideally placed to play a big role in our new curriculum -- so I blogged about it:
https://stem.wales/roll-your-own-data-logger-with-maximite-2.html
Finally, for that blog, I built and coded a simple data logger in less than 1 hour.  The code is below.  MMBasic gurus -- any tweaks?  What I'd really like is a "speedo" type dial, but am unsure where to start.....
' Basic light meter functionality - not calibrated
CLS
open "light.txt" for output as #1 ' Defaults to opening from SD Card
close #1   ' Open / Close to make sure the file exists - quick and dirty
SETPIN 7,AIN 'Uses pin number 7 for Analogue Input (AIN)
 open "light.txt" for append as #1
 light = Pin(7)  ' reads pin 7
 box 0,0,400,20,2,,rgb(black) ' draws a light meter scale
 box 0,0,light*100,20,2,,rgb(red) ' displays the current value
 teXT 450,5, format$(light*1000,"%0.0f"), "R" 'prints the current value
 print #1,TIME$, format$(light*1000,"%0.0f") 'outputs to file the time and light value
 text_log$="Logged at " + Time$ ' on screen output
 text 550,5, text_log$
 close #1 ' as we pause for 1 min, close file in case of crash
pause 60000   ' Wait 1 minute or 60000 miliseconds
Loop while INKEY$<>chr$(27) ' Exit if ESC is pressed
cls ' keeps screen tidy on exit
Posted: 09:23pm 10 Aug 2020
Hi and welcome.
(I have a sister in Wales. She was planning to come and visit in April but Covid put a stop to those plans!)
I would use a SETTICK interrupt instead of the PAUSE 60000
That allows you to do all sorts of other things while you wait. Draw a chart of the light over time perhaps.
 CLS
 OPEN "light.txt" FOR output AS #1 ' Defaults to opening from SD Card
 CLOSE #1   ' Open / Close to make sure the file exists - quick and dirty
 SETTICK 60000, myLight ' run myLight sub every 60 seconds
 DO
  ' do other things while you wait
 LOOP WHILE INKEY$<>CHR$(27) ' Exit if ESC is pressed
 CLS ' keeps screen tidy on exit
 END
SUB myLight
 OPEN "light.txt" FOR append AS #1
 light = PIN(7)  ' reads pin 7
 BOX 0,0,400,20,2,,RGB(BLACK) ' draws a light meter scale
 BOX 0,0,light*100,20,2,,RGB(RED) ' displays the current value
 TEXT 450,5, format$(light*1000,"%0.0f"), "R" 'prints the current value
 PRINT #1,TIME$, format$(light*1000,"%0.0f") 'outputs to file the time and light value
 text_log$="Logged at " + TIME$ ' on screen output
 TEXT 550,5, text_log$
 CLOSE #1 ' as we pause for 1 min, close file in case of crash
END SUB
Posted: 09:28pm 10 Aug 2020
Love it!
typo on the web page - just under the heading "The potential of creating your own logger", there's a left paren matched with a right bracket (aka square bracket).
Nimue
Posted: 09:33pm 10 Aug 2020
  JohnS said  Love it!
Cheers - good eyes -- fixed.
Nim
Sasquatch
Posted: 09:35pm 10 Aug 2020
Check out the latest version of "Lunar Lander" in this thread:
https://www.thebackshed.com/forum/ViewTopic.php?TID=12303&PID=152030#152030#152030
Andrew has done some very nice circular "speedo" type gauges.
-Carl
Nimue
  TassyJim said  Hi and welcome.
I'm in the Cardiff area -- very urban - not the pretty part unfortunatley.
Love the SETTICK feedback -- one to investigate for version II.
Nim
Nimue
Posted: 09:36pm 10 Aug 2020
  Sasquatch said  Check out the latest version of "Lunar Lander" in this thread:
Perfect - code "borrowed".....
Nim
Posted: 08:04am 11 Aug 2020
back in 1984, I did two modules for a teacher friend. They used something called a "VELA"(?)
He wanted an adaptor to shine a tungsten bulb through an inserted test tube them measure the light from it in RGB. It was a cow trimming to get even near a flat response. Got hold of some very good filters but we were fighting the emissions of the tungsten - strong in the red and tails of to hardly anything in the blue. Then the response of the ORP12s... But it was good enough in the end.
Nimue
Posted: 08:46am 11 Aug 2020
  CaptainBoing said  back in 1984, I did two modules for a teacher friend. They used something called a "VELA"(?)
VELA / Data Harvest are the "big boys" in education data loggers -- expensive and slick and Iirc you are wedded to their sensors.
FWIW: https://www.retro-kit.co.uk/VELA/
Another "roll your own" project is to make a colorimiter -- white LED emitter shining through a small cuvette and an LDR sensor --> to measure how much light passes through.    Basic high school stuff but the colorimiters cost £200+ and are black box again.
I think I'll 3D print some kit and this will be my next project.
Nim
Andrew_G
Posted: 10:53pm 11 Aug 2020
Hi Nim,
Welcome. I'm sure you will get a lot of support from Shedders for helping your young people to learn and explore.
The "gauges" in Lunar Lander are intentionally pretty basic (no pun).
Here are is a much better one. In that thread I raised a couple of issues with the ARC statement. One is that you can't apply an aspect ratio (like you can in CIRCLE). I have experimented with Panky's code above and you can multiply his SIN components by your aspect ratio and get a circle on your monitor. I abandoned it because in LL the non-circle looks better and it was getting more complex than I wanted.
If you read the manual for "MM+" ie Micromite Plus there are several standard gauges that are not (yet) part of the CMM2.
Keep up the good work,
Andrew
{Edit: I'd meant to say how much I love Wales - I spent 3 years in Manchester in the mid-seventies and Wales was a day trip for us Aussies}
Edited 2020-08-12 08:57 by Andrew_G
Nimue
Posted: 08:46am 12 Aug 2020
Andrew - good morning (for me).
Wales is beautiful -- sadly I live in the urban areas near Cardiff.  That said, the beautiful parts are a 30minute drive away.   A "day trip" for me is "Barrybados" (Google it   ).
Manchester / Liverpool - which technically a day trip would be seen as a "big drive" for us!!
Thanks for the heads up -- will check your post and the MM+ manual.
Have just coded up gauges using the Lander example -- quite easy in retrospect -- and certainly easy enough for beginners to understand (will be teaching to 10-14 yr olds).
Nim
