Local Time 12:39 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Random Number Test
Imgonna
Posted: 02:17pm 10 Aug 2020
A sweaty afternoon all (well here in the Wales / UK it's a sweaty 27'C)
Getting hands on with CMM2 and loving it.
I also love math and random numbers --- about to code up / benchmark some performance in calculating/estimating PI, so I need some reliable random numbers.
I know the CMM2 generates random numbers through hardware -- does anyone know the specifics of this?  (Just for geeky reference really).
Currently iterating through generating 10,000,000 random numbers having started with 100,1000 etc.  (generating 0 / 1 to simulate coin flipping)
Looking at the numbers generated via ChiSquared statistics - to see if they random - results in p=0.898 --> ie random (as we would expect).
Below is the code for 10,000,000 interations.
I wonder how warm the CPU will get -- BTW loved the case mode for a fan also posted here.
StartTime$ = "Start Time: "+ Time$
dim anum(2)
for y = 1 to 1
anum(0)=0
anum(1)=0
For x = 1 to 10000000
 num=int((rnd)*2)
 select case num
   case 0
     anum(0)=anum(0)+1
   case 1
     anum(1) = anum(1)+1
 end select
if x mod 10000 = 0 then
 CLS
 Print StartTime$
 Print ""
 print "Iteration", format$(x,"%.0f")
endif
next x
Print ""
print format$(anum(0),"%.0f"),format$(anum(1),"%.0f")
next y
Print ""
Print "End Time: "+ Time$
Edited 2020-08-11 00:24 by Imgonna
Imgonna
Posted: 02:33pm 10 Aug 2020
Hi
For what it's worth - 10,000,000 iterations took 5 mins 31sec.
Glen
hitsware2
Posted: 03:03pm 10 Aug 2020
I'm curious about a ' hardware '
random number generator ?
A zener diode with counter ?
Edited 2020-08-11 01:12 by hitsware2
my site
Posted: 03:28pm 10 Aug 2020
The onboard random generator is in the silicon (and thus hardware).
If, however, you wanna play with something you can "scope", this might be interesting http://www.fruitoftheshed.com/Circuit%20Ideas.Random-Bit-Generator-for-cryptographic-strength-random-numbers.ashx
Edited 2020-08-11 02:54 by CaptainBoing
Imgonna
Posted: 03:32pm 10 Aug 2020
  CaptainBoing said  The onboard randome generator is in the silicon (and thus hardware).
A quick Google of STM32 ARM  and the spec sheet mentions "coupled oscillators" -- happy with that.
Thanks for the link.
Glen
Posted: 11:16am 11 Aug 2020
  Imgonna said  I wonder how warm the CPU will get
The CPU keeps a constant speed regardless of what code it is executing or even if it is at the command prompt.  So it will not heat up under heavy processing.
Nimue
Posted: 11:57am 11 Aug 2020
Nice - my hacky logger has been recording for 18hrs now  -- so no need to consider this.
So, summer project is to make a hacky weather station......
Nim
