Local Time 17:43 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Page Copying Speed
vegipete
Posted: 07:47pm 09 Aug 2020
So how fast are the various commands that alter the entire screen?
Well, instead of having it served to me on a platter, I timed it myself:
1000 iterations of each, using MODE 1,8:
1) CLS                                 545.393  milliseconds
2) CLS RGB(MAGENTA)                    550.737
3) PAGE COPY 1,2                      7199.96
4) PAGE COPY 1,2,B                   16576.317
5) PAGE COPY 1,2,D                   12703.316
6) BLIT 0,0,0,0,MM.HRES,MM.VRES,1     7348.923
7) BLIT 0,0,0,0,MM.HRES,MM.VRES,1,4  16173.745
8) PAGE OR_PIXELS 1,2,3              12079.231
9) PAGE OR_PIXELS 1,2,2              11791.483
A) PAGE OR_PIXELS 1,1,1               7220.06
As expected, PAGE AND_PIXELS and PAGE XOR_PIXELS are the same speed as PAGE OR_PIXELS.
Number A serves no purpose other than timing. It is curiously fast though.
Number 3 is ever so slightly faster than 6 although they do the same thing.
Numbers 4 & 5 may be somewhat meaningless because they are timed to the vertical blanking and may be tripping over themselves.
Number 7, BLIT with transparency, is the most costly. This makes sense because a comparison is required for each pixel and DMA can't be used.
Do we learn anything from this?
Ideally, we should build our image on a page other than page 0, then use a vertical blanking based PAGE COPY command to cleanly (ie: without tearing) move the image to page 0 for display. PAGE COPY n,0,D is preferred if and only if our program will not change anything on PAGE n before the copy is finished. Otherwise, PAGE COPY ,0,B will pause our program until the copy is done. I am not aware of a simple means by which a program can determine when PAGE COPY n,0,D is finished. Interrupts associated with the MODE command might help.
Would the optional WHEN parameter (I, B or D) of the PAGE COPY command be a useful addition to the PAGE OR/AND/XOR_PIXEL commands?
t = timer
for i = 1 to 1000
 cls
next i
tc = timer - t
t = timer
for i = 1 to 1000
 cls RGB(MAGENTA)
next i
tm = timer - t
cls
? "cls                             ", tc
? "cls RGB(MAGENTA)                ", tm
t = timer
for i = 1 to 1000
 page copy 1,2
next i
? "page copy 1,2                   ", timer - t
t = timer
for i = 1 to 1000
 page copy 1,2,B
next i
? "page copy 1,2,B                 ", timer - t
t = timer
for i = 1 to 1000
 page copy 1,2,D
next i
? "page copy 1,2,D                 ", timer - t
page write 2
t = timer
for i = 1 to 1000
 blit 0,0,0,0,MM.HRES,MM.VRES,1
next i
page write 0
? "blit 0,0,0,0,MM.HRES,MM.VRES,1  ", timer - t
page write 2
t = timer
for i = 1 to 1000
 blit 0,0,0,0,MM.HRES,MM.VRES,1,4
next i
page write 0
? "blit 0,0,0,0,MM.HRES,MM.VRES,1,4", timer - t
t = timer
for i = 1 to 1000
 page or_pixels 1,2,3
next i
? "page or_pixels 1,2,3            ", timer - t
t = timer
for i = 1 to 1000
 page or_pixels 1,2,2
next i
? "page or_pixels 1,2,2            ", timer - t
t = timer
for i = 1 to 1000
 page or_pixels 1,1,1
next i
? "page or_pixels 1,1,1            ", timer - t
end
berighteous
Posted: 11:26pm 09 Aug 2020
neat.  how fast is your CMM2?  Mine's 400mhz
Edited 2020-08-10 09:27 by berighteous
vegipete
Posted: 01:38am 10 Aug 2020
It's a 'V' chip which I think is the 480Mhz one. Is it running that fast? Beats me.
KeepIS
Posted: 01:49am 10 Aug 2020
Manual page 46.
MM.INFO$(CPUSPEED) Returns the CPU speed as a string. This will be 400000000 for the Y version of the STM32H743II or 480000000 for the V version.
vegipete
Posted: 03:17am 10 Aug 2020
My mistake. The times listed above are with my 400MHz Waveshare board (rev Y).
My 480MHz Waveshare (rev V) times are slightly different/improved.
Here they are combined:
                                      480MHz     400MHz
1) CLS                                 452.832    545.393 milliseconds
2) CLS RGB(MAGENTA)                    457.936    550.737
3) PAGE COPY 1,2                      7154.907   7199.96
4) PAGE COPY 1,2,B                   16579.436  16576.317
5) PAGE COPY 1,2,D                   12558.197  12703.316
6) BLIT 0,0,0,0,MM.HRES,MM.VRES,1     7339.73    7348.923
7) BLIT 0,0,0,0,MM.HRES,MM.VRES,1,4  15291.557  16173.745
8) PAGE OR_PIXELS 1,2,3              12072.615  12079.231
9) PAGE OR_PIXELS 1,2,2              11645.814  11791.483
A) PAGE OR_PIXELS 1,1,1               7215.809   7220.06
Both boards are running firmware version 5.05.05b5
Only CLS and BLIT with transparency benefit from the extra 80MHz.
(I don't generally use the rev V board because it would benefit from the oscillator mod.)
Thanks KeepIS. There is so much in the manual to learn... It's all too hard.
KeepIS
Posted: 06:38am 10 Aug 2020
BTW you might want to time the difference between CLS and the BOX command. Last time I did a check on that the BOX CMD was around 50% faster at clearing the screen, however that was quite a few builds ago, I haven't installed the latest build yet.
Posted: 07:02am 10 Aug 2020
To get maximum performance it is important to understand the architecture. There is 3.5MB of memory allocated to video. The first 512Kb is in the processor and the 3Mb in the SDRAM. The processor memory is much faster than the SDRAM.
Mode 1,8 uses all of the 512KB for page 0 (800x600=480,000) so all copies are comparatively slow
Mode 2,8 has two pages in the 512KB (640x400=256,000) so copies from page 1 to page 0 and visa versa will be faster than all others.
Mode 3,8 has 4 pages in the 512Kb (320x400=128,000 - lines are duplicated)
You can play with the tests above to see the impact of different pages with different modes. Of course the tests with B and D are sort of meaningless as the time will be completely dependent on the timing of the start of the test compared to the next frame blanking.
For the avoidance of doubt BOX and CLS use the same code
You can use MM.INFO(PAGE ADDRESS pageno) to see where any given page resides. SDRAM starts at &HD0000000
Edited 2020-08-10 17:18 by matherp
MachineEmpath
Posted: 03:12am 31 Oct 2020
I've been running into page copy timing limits and have been thinking about it a bit.
In particular, I'm using mode 9,16 to do some IFS fractal rendering on page 1 and copying the result to page 0, allowing me to animate the fractal smoothly.  Unfortunately, the page copy takes more than 50ms, even when the fractal render only takes 15ms using a CSUB.
I would LOVE to have a "page read n" command (or equivalent) that would set the page that was scanned out to the VGA connector.  Since even page 0 can't fit in the internal SRAM for more 9,16, it seems like changing the scan out address to a different page should be possible.  I'm guessing it might be a bit harder when the first page is in internal SRAM and later pages are in the external SDRAM?  It would also be great to have an MM.INFO(read page) variable so you could see if the page flip had happened.
Anton
johnd
Posted: 08:25am 31 Oct 2020
I like the idea of being able to just change the video page pointer instead of having to copy/blit memory to the current video page.  If you are trying for 60fps (~16ms per page) and half of that time (~8ms) is for the page copy, that only leave 8ms to draw the page.  If you could just switch the video output to the new page, instead of having to copy it, you could skip the page copy and get a full 16ms to draw the page before flipping.  But, I don't really know if this is possible under this architecture.
Note: are the units in first post microseconds or milliseconds?   EDIT: ah, for 1000 iterations.  My bad.
Edited 2020-10-31 18:25 by johnd
vegipete
Posted: 05:38pm 31 Oct 2020
True page flipping would be nice, maybe Peter will amaze us yet again.
What does work instead is to 'page flip' while drawing. (Except this won't work for mode 9,16 because there are only 2 pages total.)
' Pseudo code for illustration only. There is only one
' draw routine, PAGE WRITE toggles active drawing page.
DO
 draw on page A
 pause until frame time expired
 PAGE COPY A, 0, D
 draw on page B
 PAGE COPY B, 0, D
LOOP
I used this technique in Rocks in Space to good effect. It removed the page copy time, giving me the full frame rate time to do the drawing.
johnd
Posted: 10:04am 01 Nov 2020
@vegipete: excellent trick.  thx
MachineEmpath
Posted: 04:04am 02 Nov 2020
Vegipete, I like that trick.  Unfortunately, even if there was enough RAM allocated to video pages it wouldn't help much in my case because it takes a full 50ms to do a single page copy in more 9,16.
Matherp, I'm noticing something else interesting.  The mode 9,16 page copy seems to be messing with the USB keyboard handling code.  It is very unresponsive, with keys taking a lot of presses to register and then getting stuck down.  At first I thought it might have been the fact that I set the repeat delay to 250,25 to make editing easier, but changing that back to the default didn't fix it.  Taking the page copy out of the render loop fixes the keyboard responsiveness.  I also tried disabling my CSUB (which only runs for a few hundred microseconds at a time) and that didn't have any effect.  This is with firmware 5.05.06RC10 on a 400MHz board.
Thanks!
NPHighview
Posted: 04:38am 02 Nov 2020
Peter, MachineEmpath -
I've noticed the keyboard issue as well.  I'm using mode 9 for the Game of Life implementation I'm working on (512x256 cells), and do screen copies after every generation (~14 sxeconds per).  The key loss / key repeat is particularly noticable after running simulations for a few hours, then going into the editor to make alterations to the code.  The rapid key repeat is particularly problematic when I hit [Esc] to leave markup mode; the [Esc] repeats cause me to lose all my edits.
I'm not using CSUBs.  I've updated to RC12.  My Maximite is running at 480MHz.
I'll see if I can come up with a minimal code demonstration; my Game of Life program is far too complex to unequivocally demonstrat the issue.  In the interim, I'll try using BLITs to copy the playing field from the update page to the visible page.
Wonderful stuff!  Thank you.
- Steve "NPHighview" Johnson
Edited 2020-11-02 14:43 by NPHighview
MachineEmpath
Posted: 05:52am 02 Nov 2020
Here is a pretty simple test case that exhibits the problems mentioned.
cls
mode 9,16
page write 1
dim integer i, a = 0
do
 a = a << 1
 for i = 1 to keydown(0)
   select case keydown(i)
     case 149 : a = a OR 1
   end select
 next
 text 0, 0, BIN$(a, 64)
 page copy 1 to 0
 pause 100
loop
You should see a string of 64 zero's at the top of the screen and when you hit F5 ones should start shifting left until you release F5.  If you change the "pause 100" to "pause 1" it starts to be flaky.  And if you remove the pause altogether then I've only been able to break out by hitting the reset button (Ctrl-C doesn't function), and I never see any ones show up.
Posted: 11:00am 02 Nov 2020
  Quote  Here is a pretty simple test case that exhibits the problems mentioned.
Thanks for the simple example - found and fixed - will post new version later today
NPHighview
Posted: 12:56am 04 Nov 2020
Hi, Peter - it looks like RC12 is still the most current one at geoffg.net/Downloads/Maximite/CMM2_Beta.zip
Did you get around to posting the newer one from yesterday?
Thank you!
