Local Time 13:46 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need help with Multi-Dimensional Arrays
Atomizer_Zero
Posted: 12:26pm 06 Aug 2020
I want to create an Array that has 3 index's, with the first being an ID, the second being an X co-ord and the third being a Y co-ord.
OPTION BASE 1
DIM MYARRAY(128,1,1)
So, for each ID, I want to use a loop and fill in the details for x and y.
I've tried a few ways. For example,
FOR ID = 1 TO 128
 MYARRAY(ID, X, Y) = MYARRAY(ID, X*8*16, Y*8*11)
   ?ID, X*8*16, Y*8*11
   X = X + 1
   IF X = 8 THEN
     X = 0
     Y = Y + 1
   END IF
NEXT ID
The intended results are:
MYARRAY(0, 0, 0)
MYARRAY(1, 128, 0)
MYARRAY(2, 256, 0)
MYARRAY(128, 1920, 616)
Here's the actual output:
0, 0, 0
1, 128, 0
ERROR: Index out of bounds.
Obviously, i'm doing it wrong... any help would be great, thanks
Posted: 12:35pm 06 Aug 2020
0, 0, 0
1, 128, 0
I think you're trying to look at index 128 of the second bound ... however that bound is only 2 elements long 0 & 1.
Atomizer_Zero
Posted: 12:39pm 06 Aug 2020
I made an error in the initial post. I mixed up using BASE 1 and the code I was testing...
So for completenes
'this is the complete program.
DIM MYARRAY(127,1,1)
FOR ID = 0 TO 127
  ?ID, X*8*16, Y*8*11
  X = X + 1
  IF X = 15 THEN
    X = 0
    Y = Y + 1
  END IF
NEXT ID
I cant create an array with MYARRAY(127,0,0), which doesn't make sense, if base 0 is default.
Edited 2020-08-06 22:41 by Atomizer_Zero
Atomizer_Zero
Posted: 01:24pm 06 Aug 2020
Im going to just do what the NES PPU does (lol).
Have an Object Attribute Array, where it has an Index (ID), and multiple poisitions in that for various data.
So,
OPTION BASE 1
DIM MYARRAY(128, 2)
FOR ID = 1 TO 128
 MYARRAY(ID,1) = X*8*16
 MYARRAY(ID,2) = Y*8*11
 X = X + 1
 IF X = 16 THEN
   X = 0
   Y = Y + 1
 END IF
NEXT ID
This should be good enough. I can expand the array downwards as needed, to include tile types and special flags, etc.
Edited 2020-08-06 23:34 by Atomizer_Zero
Posted: 01:47pm 06 Aug 2020
  Atomizer_Zero said  DIM MYARRAY(127,1,1)
FOR ID = 0 TO 127
There are 128 possible values for "ID = 0 TO 127", but you've only created buckets for 127 of them. Try "DIM MYARRAY(128,2,2)".
With option base 0, MYARRAY(127,1,1) should access the last element. OPTION BASE 0 can be confusing.
Edited 2020-08-06 23:50 by lizby
PicFan
Posted: 06:41pm 06 Aug 2020
Try this ?
OPTION BASE 0
DIM MYARRAY(127,1,1)   „You have per ID, 4 Vars.“
FOR ID = 0 TO 127
  MYARRAY(ID, 0,0) = X*8*16
  MYARRAY(ID, 0,1) = Y*8*11
  MYARRAY(ID, 1,0) = A
  MYARRAY(ID, 1,1) = B
  ?ID, X*8*16, Y*8*11
  X = X + 1
  IF X = 8 THEN
    X = 0
    Y = Y + 1
  END IF
NEXT ID
hitsware2
Posted: 07:00pm 06 Aug 2020
Having learned some BASIC before ' OPTION BASE '
was developed I find anything other than 0 confusing
my site
Posted: 07:29pm 06 Aug 2020
  Atomizer_Zero said  I made an error in the initial post. I mixed up using BASE 1 and the code I was testing...
So for completenes
FOR ID = 0 TO 127
  ?ID, X*8*16, Y*8*11
  X = X + 1
  IF X = 15 THEN
    X = 0
    Y = Y + 1
  END IF
NEXT ID
That code counts ID 0 to 127 and X from 0 to 15, Y from (unset, so zero) to (er, I think it's 7 or 8).
You'd need DIM MYARAY(127, 15, 7) 'or 8
Oh, hang on, you also use MYARRAY(ID, X*8*16, Y*8*11) so you need a lot bigger - use the max X then multiply it by 8*16 and max Y times 8*11.
I think you don't mean the code to be like that!
Edited 2020-08-07 05:30 by JohnS
Atomizer_Zero
Posted: 09:47pm 06 Aug 2020
Thanks for all the replies. It is confusing for sure. It's just as confusing as getting the data back out again. But its all good. I'm just going to do what I mentioned in post 4, where I use a 2D array, with the first index will be the index of the map, and the second index will have "slots" for data.
it "looks" like this
MYARRAY(128, 3)
VISUALLY, IT'D LOOK LIKE THIS...
ID 1_
    |_x
    |_y
    |_whatever
ID 2_
    |_x
    |_y
    |_whatever
ID 3_
    |_x
    |_y
    |_whatever
Much like a struct in c++ or a class object in java, where you give it parameters such as X, Y and so on.. To access the data, you just say "MYARRAY(ID,1)" for "X", "MYARRAY(ID,2)" for Y, etc.
Quite simple I think.
