Local Time 13:46 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Trouble in RND land
fiziwig
Posted: 02:52am 06 Aug 2020
Here's a simple program that exposes a serious bug:
Option Default Integer
dim c(9)
for i=0 to 9
 c(i)=0
next i
for i = 1 to 100000
 k = int(rnd*9+0.5)
 c(k)=c(k)+1
next i
for i=0 to 9
 f! = c(i) / 100000.0
 print i;f!
next i
There are ten possible integer outcomes, 0..9, so after running 100,000 times there should be roughly 10% in each array slot from c(0) to c(9). However, that's not what happens. Here is one sample run:
0 0.05602
1 0.10991
2 0.11019
3 0.10858
4 0.11078
5 0.11156
6 0.11264
7 0.11179
8 0.11175
9 0.05678
The distribution is wrong, with c(0) and c(9) getting only 5% and the others getting around 11%.
I get the same result if I remove the "Option Default Integer"
The distribution kinda looks like it has "tails" like a normal distribution. At any rate, there is a definite bias away from the two tails.
You can get a decent flat distrubtion with a hack like this, using some semi-large prime as a multiplier and your desired range as the modulus:
int(rnd*11213+0.5) mod 10
After 100,000 iterations this gives 10% to 4 decimal places.
flip
Posted: 03:26am 06 Aug 2020
Hi fiziwig,
There's no bug there.
  Quote  k = int(rnd*9+0.5)
The rnd*9+0.5 will give a random distribution between 0.5 and 9.5 (which the integer function changes to 0-9 but with incorrect weighting
Try
k = int(rnd*10)
Regards Phil
Edited 2020-08-06 13:27 by flip
Posted: 03:36am 06 Aug 2020
It was covered in depth not long ago.
https://www.thebackshed.com/forum/ViewTopic.php?TID=12284&PID=149205#149205#149199
