Local Time 23:45 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : tetris for Armmite F4
Posted: 03:04pm 31 Jul 2020
Just to prove I can do it, I wrote a tetris game for the Armmite F4.
The game is not finished, but it is playable.
The game plays on the ArmmiteF4 LCD, but is in this phase controlled from the PC terminal.
A move left, S move right, H rotate piece, <space> move down.
There is an anonymous high score list
The code needs cleanup, and makes use of goto and gosub a lot (sorry Geoff, MMBasic can do so much better). At least I dropped the line numbers...hihi.
Here is the current code:
' -------------------- tetris for Armmite F4 ----------------------
' the game has a playfield of 20 deep and 10 wide
' the game plays on this field, and is pasted into suitable graphics per
' platform. For F4 this is the ILI9341 320x240 display configuration
'   OPTION LCDPANEL ILI9341_16, RLANDSCAPE
'   OPTION TOUCH PB12, PC5
' keyboard controls: a/s for left-right, h for rotate, d for down,
'                    space for fast down
' empty playfield = 0, live pieces 1-6 have color 1-6.
' locked pieces color -1..-6
' to do:
'   - implement buttons at GPIO
'   - make hiscore list non volatile (F4 only)
'   - add T piece (7'th piece, forgotten)
'   - add startup screen
'   - add end screen
'   - make speed variable
' -- 31-7-2020 -------------------------------------- Volhout -----
'------------------------ declare variables -----------------------
 Dim field(10,20)  'playing field 10x20,each cell is 0(empty) or a color
 Dim pieces(6,8,4) '6 different pieces, each 4 coordinates, 4 orientations
 Dim hiscore(8)    'the hiscore list 8 deep (no player names)
 Dim colors(6)     'the 6 colors for the 6 different pieces
 'if virgin start, hiscore list is empy (adapt to non-volatile list)
 For i=1 To 8:hiscore(i)=0:Next i
'---------------------- init varaibles ------------------------
startgame:
'init all the variables for a new game
 'clear field
 For i=1 To 10:For j=1 To 20: field(i,j)=0: Next j: Next i
 'load pieces
 Restore
 For o=1 To 2: For i=1 To 6:For j=1 To 8:Read pieces(i,j,o):Next j:Next i:Next o
 Restore
 For o=3 To 4: For i=1 To 6:For j=1 To 8
   Read u
   pieces(i,j,o)=-u   'orientations 3 and 4 are mirrors of 1 and 2
 'init the colors
 colors(1)=RGB(yellow):colors(2)=RGB(red):colors(3)=RGB(blue)
 colors(4)=RGB(green):colors(5)=RGB(cyan):colors(6)=RGB(magenta)
 colors(0)=RGB(black)
 'setup game start
 score=0 : gameend=0
 startx=5 : starty=1 : startorientation=1
 o=startorientation
 c=Int(1+6*Rnd(Pi)) : cc = c 'make the first piece a random
 GoSub size
'------------------------ GAME START --------------------
 CLS
'  gosub gameintro
 CLS 'clear lcd screen
 GoSub lcdborder
 GoSub newpiece
 'start game
 SetTick 1000,godown 'here we can vary the game speed
 'SetTick 300,godown
'------------------------ GAME LOOP --------------------------
mainloop:
 'keyboard input
 a$ = Inkey$
 Pause 10 ' during this pause the "d" key is enforced by the timer
 If a$="" GoTo mainloop
 Print a$ 'debug
 'first erase the piece at the old location
 GoSub clearpiece
 'check for the change, and execute it
 'left (a) and right (s) movement
 If a$="a" And x+xl=>2 Then
     oke=1
     For i=1 To 7 Step 2 'check 4 coordinates per piece
       If field(x-1+pieces(c,i,o),y+pieces(c,i+1,o)) < 0 Then oke=0
     Next i
     If oke Then x=x-1
   End If
 If a$="s" And x+xr=<9 Then
     oke=1
       If field(x+1+pieces(c,i,o),y+pieces(c,i+1,o)) < 0 Then oke=0
     Next i
     If oke Then x=x+1
   End If
 'down will go automatic, but can also be manual
 '<space> will move the piece all the way down
 If a$="d" Or a$=" " Then
loop_d:
   score = score+1
   If y+yd=20 Then     'we are at the bottom
     GoSub lockpiece
     GoSub newpiece
   Else                'check if we can go down further
     oke=1
       If field(x+pieces(c,i,o),1+y+pieces(c,i+1,o)) < 0 Then oke=0
     Next i
     If oke Then       'if OK then we go down
       y=y+1
     Else              'if not, we lock the piece into place by changin color
       GoSub lockpiece
       If y=1 Then     'if this happens top line of field, it is game end
         gameend=1
       Else            'not game end: generate new piece
         GoSub newpiece
       End If
     End If
   End If
   If oke And a$=" " Then GoTo loop_d    'if space was hit we cycle once more
 End If
 'rotate piece to 90 degrees orientation
 If a$="h" Then
   o=(o Mod 4)+1
   GoSub adjust
 End If
 'show the changes on the board
 GoSub showpiece       'update field with the new piece locatio
 'GoSub showfield      'prints the field on the serial terminal
 GoSub lcdfield        'shows the field in graphics
 If gameend=1 Then     'at game end process high score list
   hi=score
   GoSub sortscores
   GoSub highscoreshow
   'End
   'GoSub endgame      'nice graphics to show the end
                       'with text "press key for next game"
waitforkey:
   a$=Inkey$:If a$="" Then GoTo waitforkey
   GoTo startgame      'start new game
 End If
 GoTo mainloop
'---------------------- GAME SUBS ---------------------
'sort the high score list by shifting entries down to make room
sortscores:
 i=1:added=0
sortloop:
 If hiscore(i)<hi Then
   For j=7 To i Step -1
     hiscore(j+1)=hiscore(j)
   Next j
   hiscore(i)=hi
   added=1
 Else
   i=i+1
 End If
 If added=0 Then GoTo sortloop
 Return
'generate a random new piece after checking if there is a full line
newpiece:
 GoSub checkfullline
 x=startx:y=starty:o=startorientation
 c=cc '(c Mod 6)+1
 GoSub size
 GoSub previewnext
 Return
'show the next piece (cc) in the preview window on lcd only
previewnext:
 Box 3,165,68,68,4,RGB(white),RGB(black)
 cc=Int(6*Rnd(6)+1)
 xc=3+34:yc=165+34
 For i=1 To 7 Step 2
   Box pieces(cc,i,4)*15+xc,pieces(cc,i+1,4)*15+yc,15,15,1,0,colors(cc)
 Next
 Return
'after rotation, the geometry has changed. make it fit on the field.
adjust:
 GoSub size
 If x+xl<1 Then x=1-xl
 If x+xr>10 Then x=10-xr
 If y+yu<1 Then y=1-yu
 Return
'calculate the max piece size around it's centre, after rotation
size:
 xl=Min(pieces(c,1,o),pieces(c,3,o),pieces(c,5,o),pieces(c,7,o))
 xr=Max(pieces(c,1,o),pieces(c,3,o),pieces(c,5,o),pieces(c,7,o))
 yu=Min(pieces(c,2,o),pieces(c,4,o),pieces(c,6,o),pieces(c,8,o))
 yd=Max(pieces(c,2,o),pieces(c,4,o),pieces(c,6,o),pieces(c,8,o))
 Return
'paste the piece into the playing field at location x,y
showpiece:
 For i=1 To 7 Step 2 '4 coordinates per piece
   field(x+pieces(c,i,o),y+pieces(c,i+1,o))=c
 Next i
 Return
'erase the (former) position of the piece from the playing field
'by setting the field positions back to 0
clearpiece:
   field(x+pieces(c,i,o),y+pieces(c,i+1,o))=0
 Next i
 Return
'lock a piece in position x,y by inverting the color
lockpiece:
   field(x+pieces(c,i,o),y+pieces(c,i+1,o))=-c
 Next i
 Return
'show the field array on the serial terminal. 0=empty
'1..6 = active piece,-6...-1 = locked piece
showfield:
 For j = 1 To 20
   For i = 1 To 10
      Print field(i,j);
   Next
   Print
 Next
 Return
'draw the playing field borders and fixed texts on the LCD
lcdborder:
 Box 3,3,310,160,4,RGB(white),RGB(black)
 Text 80,165+34,"score","CMU",2,,RGB(cyan)
 Text 130,165+34,"high","CMU",2,,RGB(cyan)
 GoSub highscoreshow
 Return
'interrupt timer pushes a "d" into the main loop to force a piece to move down
Sub godown
 a$="d"
'draw the active field into the playing field border and update the score
lcdfield:
 For i=1 To 10
   For j=1 To 20
     lcdx=(10.5-i)*15
     lcdy=(j-0.5)*15
     Box lcdy,lcdx,15,15,1,0,colors(Abs(field(i,j)))
   Next j
 Next i
 'score
 Text 100,165+5,Str$(score),"CBU",2,,RGB(yellow)
Return
'check if we have a full line, and remove it by copying the upper
'part of the field 1 row down. Up:y=1, down:y=20
checkfullline:
 For j=2 To 20
   oke=1
   For i=1 To 10
     If field(i,j)=0 Then oke=0
   Next i
   If oke Then
     For jj=j-1 To 1 Step -1
       For i=1 To 10
         field(i,jj+1)=field(i,jj)
       Next i
     Next jj
   End If
 Next j
 Return
'show the highscore values on the LCD
highscoreshow:
 For i=1 To 8
   Text 130+20*i,165+5,Str$(hiscore(i)),"CBU",2,,RGB(yellow)
 Next
 Return
'------------------------ PIECES --------------------------
'pieces horizontal view
Data 0,0,-1,0,0,1,1,1   'S
Data 0,0,1,0,1,1,0,1    'cube
Data 0,0,-1,0,1,0,2,0   'I
Data 0,0,1,0,0,1,-1,1   'Z
Data 0,0,1,0,-1,0,-1,1  'L
Data 0,0,-1,0,1,0,1,1   'J
'pieces vertical view
Data 0,0,0,1,1,0,1,-1   'S
Data 0,0,1,0,1,1,0,1    'cube (no difference)
Data 0,0,0,-1,0,1,0,2   'I
Data 0,0,0,-1,1,0,1,1   'Z
Data 0,0,0,-1,0,1,1,1   'L
Data 0,0,0,-1,0,1,-1,1  'J
Edited 2020-08-01 01:12 by Volhout
RonnS
Posted: 09:18pm 31 Jul 2020
many many thanks Volhout,
i like Tetris !!!.
the keypad control is suboptimal. but it looks very good.. and....  tetris is nothing without a big sound ( i remember my "AMIGA" time )
many thanks Ron
Edited 2020-08-01 07:51 by RonnS
Posted: 09:42am 01 Aug 2020
Hi RonnS,
I actually posted this tetris version with the intention to archive it, and not continue developing. The proof was given, I could write tetris.
But your response changed my mindset. I will improve the game with your suggestions.
By the way: keyboard controls sub optimal: what do you suggest as best keyboard controls (the Amiga ones ?) I am open to suggestions.
I have converted the old gameboy soundtrack to 8 bit WAV, so I can addi it to the game. The moment I played the soundtrack, old memories came back. Yes...sound is needed.
Posted: 07:52pm 01 Aug 2020
New version with sound (at pins PA4 and PA5) and non volatile highscore list
The sound is played from a file called "tet16cut.wav" that I will add to the zip
once the game is finished.
All that is needed now is more logical controls (RonnS ?) and intro screen.
And some small changes (the T piece is missing).
I ran into some issue with MMBasic with SD card files.
At the commandline you can open a file on the SD card for outputs as #1 and close it. Then open the file again for input as #1 and close it.
If you do this in the program you get an "file already open" error.
I had to re-open the file inside the MMBasic program as #2...????
I was just reminded by my wife that there where multiple tunes to choose from in the original gameboy tetris... so there is more to do...
' to do:
'   - add T piece (7'th piece)
'   - implement variable speed
' -- 1-8-2020 -------------------------------------- Volhout -----
 'if virgin start, hiscore list does not exist
 'For i=1 To 8:hiscore(i)=0:Next i: GoSub writescores
 'read hiscore list
 Open "hiscore" For input As #1
 For i=1 To 8:Input #1,hiscore(i):Next i
 Close #1
 'start endless music now
 Play volume 30    'adjust for best gameplay (0-100)
 restartplay       'start music (endless loop)
startgame:
 'clear field
 'load pieces
 Restore
o
 Restore
   Read u
   pieces(i,j,o)=-u
 'init the colors
 'setup game start
 score=0 : gameend=0
 o=startorientation
 GoSub size
 CLS
'  gosub gameintro
 GoSub lcdborder
 GoSub newpiece
 'start game
mainloop:
 'keyboard input
 a$ = Inkey$
 Print a$ 'debug
 GoSub clearpiece
     oke=1
     Next i
     If oke Then x=x-1
   End If
     oke=1
     Next i
     If oke Then x=x+1
   End If
loop_d:
   score = score+1
     GoSub lockpiece
     GoSub newpiece
     oke=1
     Next i
       y=y+1
       GoSub lockpiece
         gameend=1
         GoSub newpiece
       End If
     End If
   End If
 End If
 If a$="h" Then
   o=(o Mod 4)+1
   GoSub adjust
 End If
   hi=score
   GoSub sortscores
   GoSub highscoreshow
   'End
waitforkey:
 End If
 GoTo mainloop
sortscores:
 i=1:added=0
sortloop:
   Next j
   hiscore(i)=hi
   added=1
 Else
   i=i+1
 End If
 If (added=0 And i<8) Then GoTo sortloop
 'Return
writescores:  'overwrite highscore list
 Open "hiscore" For output As #2
 For i=1 To 8: Print #2, hiscore(i): Next i
 Close #2
 Return  'for both sortscores as writescores
newpiece:
 GoSub checkfullline
 c=cc '(c Mod 6)+1
 GoSub size
 GoSub previewnext
 Return
previewnext:
 cc=Int(6*Rnd(6)+1)
 xc=3+34:yc=165+34
 For i=1 To 7 Step 2
 Next
 Return
adjust:
 GoSub size
 Return
size:
 Return
showpiece:
 Next i
 Return
clearpiece:
 Next i
 Return
lockpiece:
 Next i
 Return
showfield:
 For j = 1 To 20
   For i = 1 To 10
      Print field(i,j);
   Next
   Print
 Next
 Return
lcdborder:
 GoSub highscoreshow
 Return
Sub godown
 a$="d"
'timed interrupt to restart the gameboy tetris tune when ended (1:16 duration)
Sub restartplay
 Play wav "tet16cut.wav",restartplay 'start music, and restart when end
 'Play wav "tet16cut.wav"
lcdfield:
 For i=1 To 10
   For j=1 To 20
     lcdx=(10.5-i)*15
     lcdy=(j-0.5)*15
   Next j
 Next i
 'score
Return
checkfullline:
 For j=2 To 20
   oke=1
   For i=1 To 10
   Next i
   If oke Then
       For i=1 To 10
       Next i
     Next jj
   End If
 Next j
 Return
highscoreshow:
 For i=1 To 8
 Next
 Return
Edited 2020-08-02 05:56 by Volhout
Posted: 06:21pm 26 Feb 2021
I finally go time to finalize the game. I have made several changes from the earier versions, although the heart remains the same.
- changed the LCD to portait more
- added the intro screen, derived from the original game boy screen
- added the music from the original game boy
- added the 7'th piece (the "T" piece was missing)
- changed the controls to the arrow keys
It is running on the new 5.07 version beta 1
when checking the code, please understand that there is still a heritage
from the original controls, that where based on characters.
For now it is finished (terminal keyboard controls) but when I change it into
a stand alone game, there will be control buttons on the GPIO pins of the F4
The intro screen
The playfield
The ZIP containing the program, intro screen, and music is below
tetris_F4.zip
Happy playing....
Edited 2021-02-27 04:30 by Volhout
Posted: 07:02pm 26 Feb 2021
  Quote  The ZIP containing the program, intro screen, and music is below
Missing the hiscore file. Tried a blank file but didn't work
Posted: 06:37am 27 Feb 2021
Thanks for testing. That was an oops on my side.
I had an "uncomment" line in the code. Have added an on-error to fix this.
And used the sort for arrays, in stead of writing my own sort.
MMBasic has so many options and usefull commands and functions.
tetris_F4.zip
For my testing of the sound I use this breadboard friendly circuit (please don't expect hifi audio from it...)
Edited 2021-02-27 17:25 by Volhout
