Local Time 14:59 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.04RC14 - performance tuning
Posted: 05:26pm 26 Jul 2020
V5.05.04RC14
http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip
Significant performance enhancements (c 10%)
More special case code for the EXECUTE command when "executing" the RUN command: It now will interpret the search path and will not tokenise text after the filename literal
Posted: 09:15pm 26 Jul 2020
Wonderful Peter, I've tested the tokenisation update to EXECUTE and it works.
Thank you,
MauroXavier
Posted: 09:34pm 26 Jul 2020
Incredible performance gain!
From 8.44 FPS to 9.45 FPS on Wolf 3D in a medium demand area (to gain one more single frame per second is a hard task in this game).
And OPTION RAM no more gives a syntax error.
Thanks a lot!
mkopack73
Posted: 02:56am 28 Jul 2020
Ok, not sure if this is the new spot to report errors...
I'm still on RC 4 but given nobody has reported this I suspect it's still a bug...
if you try to do the following:
sprite read (myvar+1), x,y,width,height,pagenum
it will give the following error:
Error: READ is not declared
Seem like it's not possible to calculate the sprite number in the read command.
I'm wondering if that's why I'm also having problems then trying to do sprite show (myvar+1)  and getting back an Error: Buffer not in use
Posted: 03:03am 28 Jul 2020
Try removing the brackets:
sprite read myvar+1, x,y,width,height,pagenum
MMBasic is looking for an array called read()
Posted: 04:05am 28 Jul 2020
A bug for you Peter.
If a variable starts with rem and is the first 'word' on a line, it is treated as a remark.
 remainder=4
 remi = 6
 remo = 8
 PRINT remainder
 PRINT remi
 PRINT remo
 DIM remain=4
 f=0 : remi = 6
 IF x = x THEN remo = 8
 PRINT remain
 PRINT remi
 PRINT remo
0
0
0
4
6
8
The work-around is to rename the variable.
Posted: 04:19am 28 Jul 2020
  TassyJim said  If a variable starts with rem and is the first 'word' on a line, it is treated as a remark.
aha! that would explain why one of the programs i wrote would never work. it was for calculating the remaining space left in a removal truck, and email you a reminder when space was getting low
rob  :-)
