Local Time 03:32 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Struggling to build some understanding of JSON
Posted: 03:52pm 20 Jul 2020
This may develop into an ongoing series of questions, but first, why doesn't this work?
> list
Dim As integer lBuff%(1000)
Dim As string A,qt
qt=Chr$(34)
A="{"+qt+"a"+qt+":1,"+qt+"b"+qt+":2,"+qt+"c"+qt+":3,"+qt+"d"+qt+":4}"
LongString append lBuff(),A
Print A
LongString print lBuff()
Print JSON$(lBuff%(),"a")
'Print JSON$(lBuff(),"a"),JSON$(lBuff(),"b"),JSON$(lBuff(),"d")
> run
{"a":1,"b":2,"c":3,"d":4}
[12] Print JSON$(lBuff%(),"a")
Error: Dimensions
This is running on an F4, "ARMmite MMBasic Version 5.05.10".
Posted: 12:26am 21 Jul 2020
Here is another failure with JSON text snagged from the internet:
[{"employees":[
   {"name":"Shyam", "email":"shyamjaiswal@gmail.com"},
   {"name":"Bob", "email":"bob32@gmail.com"},
   {"name":"Jai", "email":"jai87@gmail.com"}
> list
Dim As string A
Open "employees.txt" For input As #1
Do While Not Eof(#1)
 A = Input$(250,#1)
 LongString append lBuff%(),A
Close #1
LongString print lBuff%()
Print JSON$(lBuff%(),"employees[0].name")
> run
[{"employees":[
[14] Print JSON$(lBuff(),"employees[0].name")
Error: Dimensions
I seem to be missing something fundamental.
Edited 2020-07-21 10:30 by lizby
MikeO
Posted: 04:05am 21 Jul 2020
Hi Lisby, I did a bit of work recovering json with uMite that worked for me at the time. It didn't have much depth ability but could be the basis of some routine.
Post is here
Mike
Codenquilts
disco4now
Posted: 04:06am 21 Jul 2020
Ran your first code on a Pi-cromite and its OK. Getting the same error as you on the F4 so might be a bug.Need to try on the H7 and see what happens.
Gerry
F4 H7FotSF4xGT
disco4now
Posted: 06:04am 21 Jul 2020
List Functions (also List Commands) does not mention JSON on the Armmite F4, so I think its not supported/implemented even though command is still recognised.
list functions
^              Abs(           ACos(          And            As
Asc(           ASin(          Atan2(         Atn(           Baudrate(
Bin$(          Bin2str$(      Chr$(          Cint(          Cos(
CtrlVal(       Cwd$           Date$          DateTime$(     Day$(
Deg(           Dir$(          Distance(      Else           Eof(
Epoch(         Eval(          Exp(           Field$(        Fix(
For            GetScanLine(   GoSub          GoTo           GPS(
Hex$(          Inkey$         Input$(        Instr(         Int(
LCase$(        LCompare(      Left$(         Len(           LGetStr$(
LInStr(        LLen(          Loc(           Lof(           Log(
Max(           Mid$(          Min(           MM.Backup      MM.Device$
MM.ErrMsg$     MM.Errno       MM.FontHeight  MM.FontWidth   MM.HPos
MM.HRes        MM.I2C         MM.Info$(      MM.OneWire     MM.Ver
MM.VPos        MM.VRes        MM.Watchdog    Mod            MsgBox(
Not            Oct$(          Or             Peek(          Pi
Pin(           Pixel(         Port(          Pos            Pulsin(
Rad(           RGB(           Right$(        Rnd            Rnd(
Sgn(           Sin(           Space$(        SPI(           SPI2(
Sqr(           Step           Str$(          Str2bin(       String$(
Tab(           Tan(           TEMPR(         Then           Time$
Timer          To             Touch(         UCase$(        Until
Val(           While          Xor
Total of 123 functions and operators
> list commands
ADC            Arc            AutoSave       BackLight      Bezier
Blit           Box            Case           Case Else      Chdir
Circle         Clear          Close          CLS            Color
Colour         Const          Continue       CPU            CtrlVal(
DAC            Data           Date$          DefineFont     DHT22
Dim            Do             Edit           Else           Else If
ElseIf         End            End DefineFont End Function   End If
End Select     End Sub        EndIf          Erase          Error
Exit           Exit Do        Exit For       Exit Function  Exit Sub
FFT            Files          Font           For            Function
GoSub          GoTo           GUI            I2C            I2C2
If             Input          IR             IReturn        KeyPad
Kill           LCD            Let            Line           Line Input
List           Load           Local          LongString     Loop
Memory         Mkdir          Name           New            Next
On             OneWire        Open           Option         Page
Pause          Pin(           Pixel          Play           Poke
Polygon        Port(          Print          Pulse          PWM
RBox           Read           Rem            Restore        Return
Rmdir          Run            Save           Seek           Select Case
Servo          SetPin         SetTick        SPI            SPI2
Static         Sub            SYNC           TEMPR START    Text
Time$          Timer          Trace          Triangle       VAR
WatchDog       While          WS2812         XModem
Total of 119 commands
F4 H7FotSF4xGT
Posted: 07:01am 21 Jul 2020
  Quote   so I think its not supported/implemented even though command is still recognised.
The command isn't recognised. The F4 is interpreting json$() as an array with incorrect dimensions, one of the issues with using the same type brackets in Basic for functions and arrays unlike C
Posted: 11:59am 21 Jul 2020
  disco4now said  List Functions (also List Commands) does not mention JSON on the Armmite F4, so I think its not supported/implemented even though command is still recognised.
  matherp said  The command isn't recognised. The F4 is interpreting json$() as an array with incorrect dimensions, one of the issues with using the same type brackets in Basic for functions and arrays unlike C
Ahh, bummer. The F4 is so easy to use, and I have at least one every place I might sit and fiddle with MMBasic.
The pi will work, but needs beefier power, and the CMM2 is relatively bulky. DOS MMBasic doesn't support JSON or longstrings.
Thanks for looking. I was going to try the CMM2 today anyway.
Posted: 12:02pm 21 Jul 2020
  MikeO said  Hi Lisby, I did a bit of work recovering json with uMite that worked for me at the time. It didn't have much depth ability but could be the basis of some routine.
Post is here
Mike
Thanks, Mike--that may serve as the basis for a cross-MMBasic version for me. I don't think I will need a lot of depth--although I probably will want a longstring version.
I actually have similar code almost developed.
Edited 2020-07-21 22:07 by lizby
Posted: 02:42pm 21 Jul 2020
  lizby said  I was going to try the CMM2 today anyway.
Oops. CMM2 also lacks JSON$.
NPHighview
Posted: 07:22pm 19 Sep 2020
Thanks for the great discussion about JSON, and for the tantalizing glimpse into the functions and commands available for the F4.
I'm expecting delivery of a cmm2 in the next few days, and wonder whether "list functions" and "list commands" work in mmBasic on the cmm2, or if that's only available on the Armmite systems  They don't in the DOS version of mmBasic.
Fingers crossed!  Especially looking for documentation of the FFTand all of the other MATH xxx routines...
Edited 2020-09-20 05:26 by NPHighview
Posted: 09:23pm 19 Sep 2020
  NPHighview said  Thanks for the great discussion about JSON, and for the tantalizing glimpse into the functions and commands available for the F4.
Note that JSDON is not available on the CMM2
LIST FUNCTIONS and LIST COMMANDS are available.
You can always start reading the manuals while you wait for your delivery.
Manual available from https://geoffg.net/maximite.html
NPHighview
Posted: 01:37am 20 Sep 2020
Thanks, Jim -
I've been scouring the mmBasic manuals (DOS, cmm2, and F7) for mentions of the syntax "list functions" "list commands" or MATH xxx, and the forum as well.  Limited joy; learning by seeing what you, Peter Mather, disconow, and others are doing, here and in Fruit of the Shed, seems to be my main hope at this point.  The search function in the forum is a reasonable tool for this; it led me here while looking for documentation for the FFT routines.
I'm not looking specifically at JSON, though recursion does intrigue me.  I've written a deeply recursive  memoized Ackermann function evaluator in mmBasic for DOS (contributed to Fruit of the Shed), and some other programs (like Conway's Life and a gravity game) that I use as my calibrators when picking up a new language.  So far, mmBasic looks great.  I really look forward to playing with the cmm2.
Thanks for making this such a lively, dynamic ecosystem as well.  This is frosting on the cake!
- Steve "NPHighview" Johnson
Edited 2020-09-20 11:59 by NPHighview
