Local Time 11:34 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 COM3 Connections
Chopperp
Posted: 12:52pm 10 Jul 2020
Hi
Just wondering: If you disable the serial console, how do you actually physically connect the new serial I/O to the CMM2 (as COM3)?
Do you use the 2 USB data lines on Con1 or do you remove IC1 & connect to socket pins 5 & 6 or do something else?
Brian
ChopperP
Posted: 12:57pm 10 Jul 2020
  Quote  Do you use the 2 USB data lines on Con1 or do you remove IC1 & connect to socket pins 5 & 6
You either use USB or to use TTL then remove IC1
Edited 2020-07-10 22:58 by matherp
Chopperp
Posted: 01:03pm 10 Jul 2020
  matherp said  You either use USB
So do you just use a USB to TTL converter connected to the USB socket?
Edited 2020-07-10 23:04 by Chopperp
ChopperP
Sasquatch
Posted: 01:13pm 10 Jul 2020
IC1 IS a USB to TTL converter.  If you need a USB connection on COM3: you can just plug a cable into the "B" socket just as you would for the console.  If you need TTL serial on COM3: (for example a GPS) you should probably remove IC1 and then you can connect directly.  Keep in mind the TTL level signals are actually 3.3V and not 5V.
-Carl
Chopperp
Posted: 01:41pm 10 Jul 2020
Hi Sasquatch.
I did sort of realise that IC1 is a TTL USB converter but maybe with it disabled, the data pins could be directly used for TTL.
I was also just wondering if it would support one going the other way, save removing IC1. You would still need to supply power to the unit through the connector.
Brian.
Edited 2020-07-10 23:50 by Chopperp
ChopperP
vegipete
Posted: 04:25pm 10 Jul 2020
I would think that disabling the serial console only changes the way the firmware interprets data coming/going on com3. The hardware itself is unchanged.
Chopperp
Posted: 10:32pm 10 Jul 2020
  vegipete said  I would think that disabling the serial console only changes the way the firmware interprets data coming/going on com3. The hardware itself is unchanged.
Yes, I thinking about it, I would say that would be the case.
ChopperP
KeepIS
Posted: 12:56am 11 Jul 2020
I have removed the IC on mine and fitted the ISCP header pins. By placing two links into the IC socket, assuming you have a socket, I can use the ISCP header to plug in or switch between a WIFI link or serial link (using a cp20xxx TTL to USB convertor), and obviously use the physical port connector as 5v in. No change to the board and no wires soldered.
Mike.
Chopperp
Posted: 06:31am 11 Jul 2020
@ keepIS. Sounds like a good way to go. Thanks for that.
I was considering making an adaptor board to plug into the IC socket, & wiring in another IC socket but having the data pins going to a switch so the Waveshare board can be switched between IC1 or an external serial input.
Might be a bit cramped for room to do that.
Brian
ChopperP
KeepIS
Posted: 06:45am 11 Jul 2020
Hi Brian, that was my initial idea but I didn't have a suitable plug. Then I realised the header has 3v, GND, TTL IO by using two links in the socket and is easier to plug into. I run everything here at 240300 baud and there is a note from Microchip admitting that there is a problem with the MCP2221A at that speed, and the stupid Windows .NET framework is COM interface is a crap shoot when working with the device Driver for these, or it's own generic driver. So I use a CP201X device or the ESP8266 when talking to my Setup / test application.
Mike.
