Local Time 10:49 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Trying to draw fractal trees, odd behavior
daveculp
Posted: 09:46pm 08 Jul 2020
Im trying to draw a simple fractal tree which draws a horizontal line then recursively draws two lines from the end point of that line by rotating -25 and + 25 degrees then keeps going fro a set number of iterations.
Here is the code, a bit messy as I've been fiddling around with it.:
The print statements are simply debug statements to let me see some values and can be REM'd out.
drawTreeLeft(MM.HRES/2, MM.VRES,-90,10)
drawTreeRight(MM.HRES/2, MM.VRES,-90,10)
SUB drawTreeLeft (x1,y1, angle, iter)
  if iter >0 then
   x2 = x1 + int(cos( RAD(angle) ) * iter * 10.0)
   y2 = y1 + int(sin( RAD (angle) ) * iter * 10.0)
   print angle,":";x1,y1,":",x2,y2
   line x1,y1,x2,y2,1,RGB(brown)
   drawTreeLeft(x2,y2, angle -25, iter - 1)
   REM drawTree(x2,y2, angle +25, iter - 1)
 else
   circle x1,y1,3,1,1,RGB(GREEN), RGB(GREEN)
 end if
END SUB
SUB drawTreeRight (x1,y1, angle, iter)
 if iter >0 then
   x2 = x1 +int(( cos( RAD(angle) )) * iter * 10.0)
   y2 = y1 +int(( sin( RAD (angle) )) * iter * 10.0)
   REM drawTree(x2,y2, angle -25, iter - 1)
   drawTreeRight(x2,y2, angle +25, iter - 1)
 else
 end if
END SUB
The odd behavior is the following two things:
1.  x1 and x2 and y1 and y2 turn out to be the same and they shouldnt.  I NEVER change the value of x1 and y1.  Why is this?
2.  Problem #1 is solved if I do something like the following in the function:
  start_x = x1
  start_y = y1
  if iter >0 then
   line start_x,start_y,x2,y2,1,RGB(brown)
 else
 end if
END SUB
3.  I originally had it as one function which would call the drawTree sub twice (see the REM), one for drawing the left branch and one for the right.  However, it only ever drew the left branch.
4.  It should be recursively calling the drawTree function for EVERY LINE, but it doesn't.
I figure #3 and #4 are probably due to the way MMBASIC handles recursion and I know there is a limit of 50 recursive calls.  I will probably need to figure out another way to do this.
I cant figure out #1 though.  Why are x1 and y2 being set to x2 and y2?
Edited 2020-07-09 07:50 by daveculp
vegipete
Posted: 10:45pm 08 Jul 2020
Does it improve if you use local variables in the subroutines?
Posted: 12:14am 09 Jul 2020
How about "Christmas in July"
 ' seasons greetings
 option explicit
 option default float
 mode 1
 dim stX=mm.hres/2           'Tree starting point
 dim stY=mm.vres*0.9
 dim newX, newY, leng
 dim angle = 30 '-30
 dim stL = mm.vres/5
 dim delta = stL/7
 dim dr = 270
 dim TurtleSpeed = 15    'speed options
 DIM as float stack(100)      'FILO stack
 DIM AS INTEGER cols(6)
 cols(0)= RGB(RED)
 cols(1)= RGB(WHITE)
 cols(2)= RGB(yellow)
 cols(3)= RGB(green)
 cols(4)= RGB(blue)
 cols(5)= RGB(magenta)
 dim stackpos=1
 dim c=0
 ' melody globals
 DIM AS FLOAT melody(160,2)
 DIM AS INTEGER tonePos, endTone, endMelody, t
 endMelody = 1 ' needs to be set so that the first melody will start playing
 CLS
 do
   IF endMelody = 1 THEN
   if tempr(42) <> 1000 then ' only print temperature if available
     text stX, stY+30, " "+str$(tempr(42),2,2)+" C  ", cm
   endif
     t = (t+1) mod 2
     select case t ' rotate melodies
       case 0
         RESTORE jingleBells
       case 1
         restore jinglebells2
     end select
     playMelody
   ENDIF
   newX=stX
   newY=stY
   leng = stL
   angle = 0 - angle ' flip this each cycle to give windscreen washer action
   dr = 270
   c=(c+1) mod 6
   LINE newX, newY-1, newX, newY ,1,cols(c)
   drawtree
 loop
END
SUB drawtree
 local oldx, oldy, c, n
 IF endTone = 1 THEN playNextTone
 IF (leng > 0) THEN
   c = int(rnd()*6)
   oldX=newX
   oldY=newY
   newX=oldX - COS(RAD(dr))*leng
   newY=oldY + SIN(RAD(dr))*leng
   LINE oldX, oldY, newX, newY,1,cols(c)
   for n = 1 to TurtleSpeed ' break up the pause to allow for the tune to play smoothly
   PAUSE 1
   next n
   dr=dr+angle
   stack(stackpos)=leng
   stackpos=stackpos+1
   leng = leng - delta
   drawtree    'recursive calling itself
   dr=dr-(angle * 2)
   dr=dr+angle
   stackpos=stackpos-1
   leng = stack(stackpos)
   oldX=newX
   oldY=newY
   newX=oldX - COS(RAD(dr)+3.14159)*leng
   newY=oldY + SIN(RAD(dr)+3.14159)*leng
   PAUSE 1
   next n
   text stX, stY+10, time$, cm
 ENDIF
END SUB
 ' music melodies
SUB playMelody
 LOCAL AS INTEGER n
 ' assumes that the DATA pointer has been restored
 ' and the DATA ends with a pair of zeros
 tonePos = 0
 endMelody = 0
 FOR n = 1 TO 160
   READ melody(n,1), melody(n,2)
   IF melody(n,1) + melody(n,2) = 0 THEN EXIT FOR
 NEXT n
 endTone = 1 ' ready to start playing
END SUB
SUB toneEnd
 endTone = 1
END SUB
SUB playNextTone
 endTone = 0
 tonePos = tonePos + 1
 'settick 0,0,1  'turn off the 'rest' timer
 ' print melody(tonePos,1),melody(tonePos,2)
 if melody(tonePos,1) + melody(tonePos,2) > 0 then
   play tone melody(tonePos,1),melody(tonePos,1),melody(tonePos,2),toneEnd
 else
   ' don't re-set the end of tone flag
   ' just flag the end of melody
   endMelody = 1
 endif
end sub
 ' frequency, time pairs of DATA
 ' a zero frequency indicates a period of silence
 ' 0, 0 to indicate end of the melody
JingleBells:
 DATA  392.0,  240.0, 659.3,  240.0, 587.3,  240.0, 523.3,  240.0
 DATA  392.0,  960.0, 392.0,  240.0, 659.3,  240.0, 587.3,  240.0
 DATA  523.3,  240.0, 440.0,  960.0, 440.0,  240.0, 698.5,  240.0
 DATA  587.3,   28.2, 493.9,  240.0, 392.0,  240.0, 493.9,  240.0
 DATA  587.3,  240.0, 784.0,  360.0, 784.0,  120.0, 698.5,  240.0
 DATA  587.3,  240.0, 659.3,  960.0, 392.0,  240.0, 659.3,  240.0
 DATA  587.3,  240.0, 523.3,  240.0, 392.0,  960.0, 370.0,  120.0
 DATA  392.0,  240.0, 587.3,   28.2, 523.3,  240.0, 440.0,  960.0
 DATA  440.0,  240.0, 698.5,  240.0, 659.3,  240.0, 587.3,  240.0
 DATA  784.0,  240.0, 784.0,  120.0, 740.0,  120.0, 784.0,  120.0
 DATA  740.0,  120.0, 784.0,  120.0, 830.6,  120.0, 784.0,  123.1
 DATA  659.3,  240.0, 587.3,  240.0, 523.3,  480.0, 784.0,  480.0
 DATA  659.3,  240.0, 659.3,  240.0, 659.3,  360.0, 622.3,  120.0
 DATA  659.3,  240.0, 784.0,  240.0, 587.3,  123.1, 659.3,  960.0
 DATA  698.5,  240.0, 698.5,  240.0, 698.5,  360.0, 698.5,  120.0
 DATA  698.5,  240.0, 659.3,  240.0, 659.3,  240.0, 659.3,  120.0
 DATA  659.3,  120.0, 659.3,  240.0, 587.3,  240.0, 587.3,  240.0
 DATA  659.3,  240.0, 587.3,  960.0, 0,0
' End of JingleBells
JingleBells2:
 DATA  392.0,  210.0,   0.0,   30.0, 659.3,  210.0,   0.0,   30.0
 DATA  587.3,  210.0,   0.0,   30.0, 523.3,  210.0,   0.0,   30.0
 DATA  392.0,  840.0,   0.0,  120.0, 392.0,  210.0,   0.0,   30.0
 DATA  659.3,  210.0,   0.0,   30.0, 587.3,  210.0,   0.0,   30.0
 DATA  523.3,  210.0,   0.0,   30.0, 440.0,  840.0,   0.0,  120.0
 DATA  440.0,  210.0,   0.0,   30.0, 698.5,  210.0,   0.0,   30.0
 DATA  587.3,   24.7,   0.0,    3.5, 493.9,  210.0,   0.0,   30.0
 DATA  392.0,  210.0,   0.0,   30.0, 493.9,  210.0,   0.0,   30.0
 DATA  587.3,  210.0,   0.0,   30.0, 784.0,  315.0,   0.0,   45.0
 DATA  784.0,  105.0,   0.0,   15.0, 698.5,  210.0,   0.0,   30.0
 DATA  587.3,  210.0,   0.0,   30.0, 659.3,  840.0,   0.0,  120.0
 DATA  392.0,  840.0,   0.0,  120.0, 370.0,  105.0,   0.0,   15.0
 DATA  392.0,  210.0,   0.0,   30.0, 587.3,   24.7,   0.0,    3.5
 DATA  784.0,  210.0,   0.0,   30.0, 784.0,  105.0,   0.0,   15.0
 DATA  740.0,  105.0,   0.0,   15.0, 784.0,  105.0,   0.0,   15.0
 DATA  830.6,  105.0,   0.0,   15.0, 784.0,  107.7,   0.0,   15.4
 DATA  523.3,  420.0,   0.0,   60.0, 784.0,  420.0,   0.0,   60.0
 DATA  659.3,  210.0,   0.0,   30.0, 659.3,  210.0,   0.0,   30.0
 DATA  659.3,  315.0,   0.0,   45.0, 622.3,  105.0,   0.0,   15.0
 DATA  659.3,  210.0,   0.0,   30.0, 784.0,  210.0,   0.0,   30.0
 DATA  587.3,  107.7,   0.0,   15.4, 659.3,  840.0,   0.0,  120.0
 DATA  698.5,  210.0,   0.0,   30.0, 698.5,  210.0,   0.0,   30.0
 DATA  698.5,  315.0,   0.0,   45.0, 698.5,  105.0,   0.0,   15.0
 DATA  698.5,  210.0,   0.0,   30.0, 659.3,  210.0,   0.0,   30.0
 DATA  659.3,  210.0,   0.0,   30.0, 659.3,  105.0,   0.0,   15.0
 DATA  659.3,  105.0,   0.0,   15.0, 659.3,  210.0,   0.0,   30.0
 DATA  587.3,  210.0,   0.0,   30.0, 587.3,  210.0,   0.0,   30.0
 DATA  659.3,  210.0,   0.0,   30.0, 587.3,  840.0,   0.0,  120.0, 0,0
' End of JingleBells2
Posted: 06:31am 09 Jul 2020
  daveculp said  The odd behavior is the following two things:
I wonder if in each drawtree you need
local x2, y2
I'm not sure if you meant not to specify any types and are happy with the default.
Edited 2020-07-09 16:33 by JohnS
Posted: 06:50am 09 Jul 2020
  Quote  Passing Arguments by Reference
If you use an ordinary variable (ie, not an expression) as the value when calling a subroutine or a function, the
argument within the subroutine/function will point back to the variable used in the call and any changes to the
argument will also be made to the supplied variable. This is called passing arguments by reference.
 CLS
 LOCAL xx1, yy1
 xx1 = x1
 yy1 = y1
 IF iter >0 THEN
   x2 = xx1 + INT(COS( RAD(angle) ) * iter * 10.0)
   y2 = yy1 + INT(SIN( RAD (angle) ) * iter * 10.0)
   PRINT angle,":";xx1,yy1,":",x2,y2
   LINE xx1,yy1,x2,y2,1,RGB(BROWN)
 ELSE
   CIRCLE x1,y1,3,1,1,RGB(GREEN), RGB(GREEN)
 END IF
END SUB
 LOCAL xx1, yy1
 xx1 = x1
 yy1 = y1
 IF iter >0 THEN
   x2 = xx1 +INT(( COS( RAD(angle) )) * iter * 10.0)
   y2 = yy1 +INT(( SIN( RAD (angle) )) * iter * 10.0)
   PRINT angle,":";xx1,yy1,":",x2,y2,"**"
 ELSE
 END IF
END SUB
