Local Time 10:48 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MOD (modulo) operator strangeness
daveculp
Posted: 01:02am 06 Jul 2020
Im writing a game of life and I wanted the board to wrap around.  Normally I do this with the modulo operator. Example:
The left most column (0) should wrap around to the right most column (49).  So, if I want to get the state of that cell I could do something like this (in Python)
num_neighbors += board[row] [ (col-1) % NUM_C]
If col = 0 and NUM_C represents the max number of columns (50),this would result in
-1%50
Which would be 49 and therefore wraps around to the last (50th) column (starting from 0).
I tried this on the CMM2 and it claims the statement
-1 MOD 50
is -1.
That doesn't seem right.
daveculp
Posted: 01:05am 06 Jul 2020
I can write my own modulus function doing something like this:
PRINT modulus(-1,50)
FUNCTION modulus (numerator, denominator) AS INTEGER
   modulus=numerator-INT(numerator/denominator)*denominator
END FUNCTION
This properly returns 49
Edited 2020-07-06 11:08 by daveculp
daveculp
Posted: 01:49am 06 Jul 2020
Well, I just learned that using negative numbers with modulo is "undefined" and different in different languages.
https://en.wikipedia.org/wiki/Modulo_operation
"When either a or n is negative, the naive definition breaks down, and programming languages differ in how these values are defined."
I will just use my function above.
KeepIS
Posted: 04:25am 06 Jul 2020
Thanks for following this one through, another thing to put in the notes.
Mike.
Posted: 04:56am 06 Jul 2020
My way of catching small negative numbers is to add the divisor to the dividend first.
a = -1
b = 50
print a mod b
print (a+b) mod b
If you are likely to have big excursions, make it a multiple of the divisor.
