Local Time 10:47 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Random number behavior
daveculp
Posted: 09:39pm 03 Jul 2020
Ive been messing around the CMM2 and today I was writing a simple random walker routine.  It works like so:
1. Start in the middle of the screen
2. Generate a random color
3. Generate a random x offset in the range -1,0,1
4. Generate a random y offset in the range -1,0,1
5. Plot the point
6. Pause a bit
7. Go back to 2 and do it all over again
It can make some interesting shapes but I noticed the random number generation didnt seem uniform so I kept track of how many times each number is generated.
It turns out that the middle number (1) is being generated almost twice as much as the other two. Is this due to how MMBasic converts from a float to an int.  Is there a better way to do this?
In reality, the way this implementation  works is it generates a number in the range of 0 to 2 inclusive then subtracts 1 to get the range of -1 to 1 inclusive.
REM ================================================================================
REM RANDOM WALKER
x = MM.HRES/2
y = MM.VRES/2
DIM x_total(2)
DIM y_total(2)
DIM INTEGER step_x, step_y
cls black
do while INKEY$ = ""
 r = rnd * 255
 g = rnd * 255
 b = rnd * 255
 step_x = (rnd*2)
 x_total(step_x) = x_total(step_x) + 1
 step_y = (rnd*2)
 y_total(step_y) = y_total(step_y) + 1
 step_x = step_x - 1
 step_y = step_y - 1
 x = x + step_x
 y = y + step_y
 pixel x,y, RGB(r,g,b)
 pause (10)
loop
print "x totals: ";x_total(0), x_total(1), x_total(2)
print "y totals: ";y_total(0), y_total(1), y_total(2)
Edited 2020-07-04 07:44 by daveculp
daveculp
Posted: 10:07pm 03 Jul 2020
The last run resulted in the following totals:
x totals:  2312  4464  2264
y totals:  2182  4546  2312
The numbers represent the number of times 0, 1 and 2 were generated.  One is generated 2X as much as the other numbers.  Im wondering if it has to do with how numbers are converted from floating point types to integers.
Posted: 10:26pm 03 Jul 2020
It is safer to control the conversion from float to INT yourself.
step_x = int(rnd*3)
That will give you a very well distributed series of random numbers.
daveculp
Posted: 10:30pm 03 Jul 2020
  TassyJim said  It is safer to control the conversion from float to INT yourself.
step_x = int(rnd*3)
Works beautifully now!  Thanks!
Posted: 10:39pm 03 Jul 2020
In the version posted, with
step_x = (rnd*2)
step_x should never be as large as 2 (because rnd is - or should be - always less than 1).
So how is x_total(2) not 0?
What am I missing?
It looks like rnd is broken or else array indexing / the calculation of the index is.
Edited 2020-07-04 08:41 by JohnS
Posted: 10:53pm 03 Jul 2020
Going from float to INT uses rounding, not INT
The first methods used could be regarded as 4 bins 0-0.5, 0.5-1.0, 1.0-1.5, 1.5-2.0
The middle two get bundled together.
Posted: 10:54pm 03 Jul 2020
When assigning a float to an integer MMBasic will round the float to the nearest integer.  RND gives a number between 0 and 0.999999 so step_x = (rnd*2) could be rounded up to 2.
However the INT() function simply discards the fractional portion.  So INT(rnd*2) will never return 2.
EDIT: Jim beat me to it.
Edited 2020-07-04 08:55 by Geoffg
daveculp
Posted: 11:27pm 03 Jul 2020
  TassyJim said  Going from float to INT uses rounding, not INT
Based upon my experimentation I figured that was what was going on, I just wasnt sure how to fix it.  Now I know to convert manually from a FLOAT to INT instead of having it do it automatically.
Edited 2020-07-04 09:31 by daveculp
daveculp
Posted: 11:36pm 03 Jul 2020
This also helped me fix anoyjer issue with a Sierpienski's triangle generation program.  The triangle got generated but it was obviously less filled in in places, which would only happen if there was not an even distribution of random numbers.  Applying this fixed it.
panky
Posted: 01:18am 04 Jul 2020
  Geoffg said
...... the INT() function simply discards the fractional portion.  So INT(rnd*2) will never return 2.
Geoff, for negative numbers, does INT not round to the next more negative number? Ie. INT(-2.11) will round to -3 whereas FIX will just delete the fractional component of both positive and negative numbers?
panky
Posted: 02:35am 04 Jul 2020
  panky said  Geoff, for negative numbers, does INT not round to the next more negative number? Ie. INT(-2.11) will round to -3 whereas FIX will just delete the fractional component of both positive and negative numbers?
Yes, correct.  You should use FIX() when you want a true integer conversion without any rounding.  But in this case it worked as there were no negative numbers.
It is a bit confusing but blame Bill because that is how he did it in Microsoft BASIC.
Posted: 09:57am 04 Jul 2020
  Geoffg said  When assigning a float to an integer MMBasic will round the float to the nearest integer.
Oh!
I don't recall other BASICs doing that.  They do an implied FIX.
Posted: 11:13am 04 Jul 2020
  JohnS said  Oh!
From the GWBASIC User's Manual:
Posted: 04:48pm 04 Jul 2020
So I gather.
It's a big surprise to me, as some (many?) others do not do that.  Could make porting programs a bigger challenge than might be expected.
I just checked, and by way of example DEC's BASIC-PLUS truncates.
I wonder what the ANSI standard says.
(I suspect I've never used anything but an integer for an array index, however.)
Posted: 12:16am 05 Jul 2020
  JohnS said  by way of example DEC's BASIC-PLUS truncates.
MMBasic tries to keep compatibility with Microsoft BASIC.
Annoyingly the ANSI standard does not cover integer types but it does specify that floats must be rounded when indexing arrays (which is an integer conversion).
Posted: 01:16pm 05 Jul 2020
It makes sense to do that.
It also explains why the outer two (indices 0 & 2) of the totals posted roughly sum to the middle one.
