Local Time 09:39 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I have ( I think ? ) asked before , but can't remember .....
hitsware2
Posted: 01:16am 02 Jul 2020
Could the CMM2 have been designed to boot from the SD card ...
without the need of a mainline P.C. to load the ' firmware ' ?
my site
Posted: 01:22am 02 Jul 2020
The question has been asked before. If not you, someone else.
The answer is "no"
While there has been a lot of firmware updating going on at the moment, this will settle down soon and updates will probably be a few times a year.
Edit. I should have said "No not for the foreseeable"
Edited 2020-07-02 11:27 by TassyJim
hitsware2
Posted: 02:25am 02 Jul 2020
What is it that separates it from ( say )
a Raspberry Pi ?
Processor vs. controller ?
The Pi ( pre version 4 ) evidently has enough on
ROM or ? to start the boot .
I am only curious and mean not the slightest negativity .
Edited 2020-07-02 12:27 by hitsware2
my site
Posted: 07:01am 02 Jul 2020
I can't recall if the ST internal boot code supports SD reading - have a look at their site.
I suspect it doesn't, in which case the answer is no.
If that's the case, once programmed it could do so if that initial program added that feature, but that would still leave the overall answer as no.
You don't need a PC, anything running Linux (for example) will do, if it can connect to the CMM2.  E.g. a Raspberry Pi.  I provided a detailed write-up.
GregZone
Posted: 07:15am 02 Jul 2020
Even if you could boot from SD card, wouldn't you still need a PC to obtain the SD Card image and then write it out to an SD Card?
Even if you bought a pre-written "boot" SD Card, you'd still need a PC in order to apply firmware updates (as the CMM2 doesn't have Internet access to download updates directly).
Of course, if you don't have a PC and you want a CMM2, then just buy a pre-assembled CMM2 (instead of a kitset), and live with the fact that a later firmware update is going to require someone with a PC (either way).
Posted: 08:04am 02 Jul 2020
The CMM2 has no provisions for connecting itself to the internet (ethernet / WIFI).
Updates will require a PC regardless the update method (SD card / USB / etc..).
Posted: 11:58am 02 Jul 2020
Even the RPi needs a machine such as a PC to create its boot SD.
I'm now wondering who has no PC and not even something they could use or borrow yet would buy a CMM2.  If they exist, get it programmed :)
