Local Time 08:26 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM1/2: Programmatic manipulation of MMBasic
Posted: 02:43pm 12 Jun 2020
Hi folks,
As part of the task of automating the creation of a CMM1 version of my Z-machine from the CMM2 source code I will need a tool or tools to:
1. Merge in all #Included files
2. Conditionally include/exclude sections of code
3. Shorten the names of variables, functions and subroutines
4. Discard all unnecessary comments and other whitespace
If necessary I can write this all myself, hopefully in MMBasic, failing that in Python.
However if there is existing code I can beg or borrow for some or all of this then that would make my life easier.
I've already found: http://www.fruitoftheshed.com/MMBasic.MMBasic-Source-Compression-Utility-CRUNCH-bas-v2-4-part-of-the-original-MMBasic-library.ashx?HL=crunch
Is there anything else I should be aware of?
Edited 2020-06-13 02:11 by thwill
disco4now
Posted: 11:09pm 12 Jun 2020
This post has details of an addition I have used on MMEdit. It probably won't work with the latest version 4.0 MMedit as help files have changed, but OK with 3.8 versions.
MMReplace
MMedit will merge include files.
The MMReplace addon gives the #REPLACE directive allowing replacement of variable names etc with shorted ones at load time.
The #LIBRARYSTART #LIBRARYEND directives can be used to exclude code from loading.I think I also allowed /*    */ block comments as well.
MMEdit can be set to remove comments, white space.
You would need to edit your code in MMEdit and upload each time.
May or may not be suitable.
Reguards
Gerry
F4 H7FotSF4xGT
Posted: 12:03am 13 Jun 2020
Thanks Gerry,
Looks cool, but unfortunately as it currently is it doesn't fit into my Windows-free toolchain.
Looks like you distribute the source, so I could try and port it to MMBasic, any gotchas you'd like to warn me about before I look into that further?
disco4now
Posted: 02:05am 13 Jun 2020
None I know of. MMBasic string length limitations would mean it needs a fair bit of rework, as PureBasic lets me put big strings/files into memory and process them there.
F4 H7FotSF4xGT
Posted: 10:19pm 13 Jun 2020
If you are willing to stoop to 'wine', MMEdit and very probably MMReplace work under wine OK.
Gerry, I think that MMReplace will still work with the V4x of MMEdit. If not, I should be able to tweak things for you.
The changes to syntax files are not too much of a handicap to you either.
Now that I am using PB to do the variable report, I will reconsider the option to reduce variable names.
No promises.
Posted: 10:28pm 13 Jun 2020
Thanks Jim, but I'm running on a Pi and AFAIK Wine does not run on ARM.
No worries,
Posted: 08:00am 21 Jun 2020
This is probably directed at Peter or Jim, but does anyone have a list of CMM2 MMBasic keywords to hand so I don't have to construct one myself from the manual?
Thanks in advance,
Posted: 08:04am 21 Jun 2020
  Quote  does anyone have a list of CMM2 MMBasic keywords
LIST COMMANDS
LIST FUNCTIONS
Posted: 08:08am 21 Jun 2020
Keywords you can get from LIST COMMANDS and LIST FUNCTIONS
The lists don't include the parameters for the various commands.
This list does include many of the parameters but also includes keywords for all devices, not just the CMM2
allKeywords.zip
Hope that helps a bit.
LIST COMMANDS
LIST FUNCTIONS
Or in other words RTFM
I'm waiting a couple of months before printing a copy to obsessively read.
Thanks,
Chopperp
Posted: 08:23am 21 Jun 2020
I think quite a few of us are waiting for the dust to settle so to speak before we put printer ink/toner to paper. I know I am.
@ Jim, what do we open the allkeywords.TKN file with?
Edited 2020-06-21 18:26 by Chopperp
ChopperP
Posted: 08:27am 21 Jun 2020
It's just a text file
Chopperp
Posted: 08:38am 21 Jun 2020
OK. One long continuous list to sort out.
Edit. Thinking about the list. You sure have put a fair bit of time & effort into MMEdit.
Much appreciated.
Thanks.
Edited 2020-06-21 20:30 by Chopperp
ChopperP
Posted: 12:03pm 21 Jun 2020
  Chopperp said  You sure have put a fair bit of time & effort into MMEdit.
Much appreciated.
Thanks.
9 years.
Not as long as Geoff
Chopperp
Posted: 12:21pm 21 Jun 2020
  TassyJim said  Not as long as Geoff
You're too modest.
BTW, the CMM2 was/is a great team effort.
Looking forward to more MMEdit updates.
Brian
ChopperP
Posted: 01:44pm 21 Jun 2020
  TassyJim said  This list does include many of the parameters but also includes keywords for all devices, not just the CMM2
allKeywords.zip
That's neat and just what I need to write a lexer/tokenizer to run on the CMM itself.
Posted: 07:52pm 21 Jun 2020
Hi Jim,
Hopefully you don't mind a couple of follow up questions to help me out with my tokenizer:
1. What's the distinction between the 3 lists that file contains:
- List 1: looks like keywords
- List 2: I'm guessing is the "constant" parameter values used for some commands/functions though I'm not sure why the VAR from PEEK/POKE is in the first list but for example BLACK is in the second ... I guess BASIC syntax can be a little heterogenous sometimes.
- List 3: I haven't a clue.
2. Why the need for 3 variants in some cases, for example mid, mid$, mid$( ?
Not sure if it is helpful but I notice the following appear twice in the .tkn file, and those marked * appear twice in the same list:
select *
case *
tempr *
start *
gps
append
autorun
base
baudrate
bitmap
calibrate *
copy
default
disable *
explicit
float
hide *
integer
interrupt *
mp3
none
pullup *
show *
write *
Edited 2020-06-22 06:39 by thwill
Posted: 10:17pm 21 Jun 2020
  thwill said  Hi Jim,
The list is a compilation of many different lists. one for each variant of 'mite. There is a lot of manual checking but it still needs more. Having duplicates doesn't worry my programs so it's not a high priority.
More important to add missing words.
Ideally, the 3 sections will end up as different colours in the editor.
That's a future aim and for now there is no practical difference although I have been adding keywords to the first list.
mid, mid$, mid$( is needed so that as the user enters a variable, he/she is warned that they have entered a keyword as soon as the first part is entered. If the list only had the full mid$(, an illegal use of MID as a variable would not be noticed.  It depends on the lexicon used for the editor.
When it comes to parameters, things get difficult.
It is legal to use LENGTH or FLOAT as variables or user function names but I would prefer them to be flagged as keywords.
In general, I have excluded any parameter that is one or two letters long but there are dozens more I could add.
Thank you for the list of duplicates. I will update my file.
