Local Time 05:44 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug in INPUT$ function ?
Posted: 11:16pm 16 May 2020
Hey CMM2 gurus,
Run the attached file on CMM and CMM2.
input_.bas.zip
On CMM output is:
Len    = 251
Last 3 = 49 13 10
On CMM2 output is:
Len    = 252
Last 3 = 13 10 0
I believe the CMM is correct and the CMM2 is wrong.
Hope this helps,
Posted: 06:13am 17 May 2020
I agree that there is a problem.
If you try and read past the end of a file using INPUT, there is a zero byte character appended.
