Forum Index : Microcontroller and PC projects : CMM2 Manual Errata
| Page 1 of 6 |
Page 21 of Colour Maximite 2 User Manual MMBasic Ver 5.05.02 Near the bottom in the example of variables being initialized when they are defined, i% is initialized to '&FHHHHHHH' - that looks like a typo. Ought to be '&HFFFFFFF' Edited 2020-05-13 08:24 by vegipete Visit Vegipete's *Mite Library for cool programs. |
Perhaps that is an expression in Flexidecimal? ![]() Micromites and Maximites! - Beginning Maximite |
Also in the Micromite User Manual page 34: Easy to miss. Bill Keep safe. Live long and prosper. |
Thanks guys. Geoff Graham - http://geoffg.net |
@Geoff, Couple more manual errors I think:- Page 46 - for the NOT INV option, the description says 'NOIT' instead of 'NOT' Page 40 - the DHT22 is referred to as DHD22 in the program example Page 63 - LOAD GIF has what appears to be wrongly included text at the end of the description. Also, LOAD GIF seems to be a duplicate of the lower down LOAD command? Cheers, Doug. PS. Hanging out for my CMM2 to arrive ![]() ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Thanks Doug. Geoff Graham - http://geoffg.net |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 910 |
Geoff, As I've said elsewhere, a great effort by the team and the manuals are fantastic. Here are some picky comments: Parts List: Manual says "Optional Dallas DS10B20" - should be DS18B20 Resistor 4.7K if optional DS10B20 is used - should be DS18B20 Programming . . .: Page 51 and elsewhere, is it worth saying that, in the Text statement, the use of (" ") for the alignment parameters is optional? (I didn't know until I checked it on a MM) User Manual: Page 19, F6 description has two "." A brilliant effort, Andrew |
Not a manual error as such but the schematic in the construction pack shows an MCP2221A chip in place of the PIC16F1455-I/P and an ICSP header which I don’t think exists in the final design. Bill Edit: Oops I see the MCP2221A is mentioned in the parts list but so is the DS10B20 as mentioned above. Second edit: Now I see the ICSP header in CG's board and matherp's boards but the connections to it from the USB bridge on the schematic are different to the Microbridge. I'm confused. Edited 2020-05-19 16:29 by Turbo46 Keep safe. Live long and prosper. |
Bill, The MCP2221A is basically a pre-programmed Microbridge so if you have the MCP2221A, there is no use for the ICSP header. I used a PIC16F1455-I/P but programmed it on a breadboard using a micromite so didn't need the ICSP header either. Jim VK7JH MMedit |
Ah, Thanks Jim, I realised that but thought the the ICSP header was to program an external Micromite or something that's why I was confused. Bill Keep safe. Live long and prosper. |
Page 39 of CMM2 Manual 5.05.02 Infrared Remote Control Transmitter section, near the bottom of the page. Text reads "Any I/O pin on the Micromite can be used..." Ought to read "... Colour Maximite 2 ..." Visit Vegipete's *Mite Library for cool programs. |
Page 20 and 72 of CMM2 Manual 5.05.02 Number of bits for a floating point number. Page 20 describes a floating point number as "Double Precision Floating Point" ie 64 bits Page 72 in the POKE FLOAT command says a 32 bit float value will be stuffed into memory. This is inconsistent. Visit Vegipete's *Mite Library for cool programs. |
Just a minor thing: In the construction pack Parts List, the two hyperlinks include the closing bracket and full stop ")." causing them to fail. Bill Keep safe. Live long and prosper. |
Not really an error but a suggestion. In the Colour Maximite 2 User Manual under the "FILES" command description can you please add a note to point users of other 'mites and BASICs to the "LIST FILES" command. It may help avoid some confusion as "LIST FILES" is not very intuitive. Bill Keep safe. Live long and prosper. |
Missing form the manual: SORT array() [,indexarray()] This command takes an array of any type – integer, float or string and sorts it in place. It has an optional parameter indexarray. If used this must be an integer array of exactly the same size as the array to be sorted. Indexarray need not be initialised with any data but if specified will return with the original position of the value in the array being sorted. Jim VK7JH MMedit |
Array() is a single dimension array only? IE: not suitable for a 2 dimension array for a database? Bill Keep safe. Live long and prosper. |
Yes, but indexarray gives you everything you need and is more powerful as it can deal with different types of data: set up any types of arrays needed to hold your data structure e.g. name$, address$, age% copy array to be sorted to a temporary array and sort it. Then use the index into the original arrays dim name$(100),age%(100),address$(100),sortindex%, temp%(100) for i=0 to 100 sortindex%(i)=i temp%(i)=age%(i) ' sort temp%(),sortindex%() ' for i=0 to 100 k=sortindex%(i) print name$(k),age%(k),address$(k) next i Edited 2020-05-24 18:03 by matherp |
Thanks Peter, I thought it would be like that but wasn't sure. It small examples like that that help a lot with the nitty gritty details. Like your excellent graphic tutorial. Bill Keep safe. Live long and prosper. |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2983 |
Geoff, All, On page 49 top paragraph. On RESETTING the CMM2 it states (by linking pins 49 and 39 on the rear I/O connector during power up) It should be (by linking pins 40 and 39 on the rear I/O connector during power up) Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Thanks Mick and everyone. These reports are invaluable. Geoff Geoff Graham - http://geoffg.net |
| Page 1 of 6 |
