Local Time 05:44 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD card access error with MM+ V5.05.02
pjmart
Posted: 03:53am 10 May 2020
I have just upgraded my Ex100 from v5.2 to v5.05.02 and am now getting error messages when using the DIR$() function as follows:
f$=DIR$("*.*",VOL)  error:INVALID FLAG SPECIFICATION
f$=DIR$("*.*",DIR   no error but sub directories are blank ""
f$=DIR$("*.*")      error:SYNTAX
There are 2 sub directories on the SD card plus a volume title. The sub directories are displayed correctly by the FILES command and the CWD$ function.
The function f$=DIR$("*.*",FILE) works, successfully finding all files.
Is it possible that I have done something wrong when loading the new firmware causing this or is there a bug in the latest version?
Posted: 05:04am 10 May 2020
I don't have an E100/E64 handy but try
f$=DIR$("*",DIR)
The wildcard *.* doesn't find files/folders without any extension.
pjmart
Posted: 06:24am 10 May 2020
Thanks TassyJim, that fixes the DIR file search.  Perhaps could be clarified in future manuals.
However the error associated with VOL search remains.
I did try f$=dir$("*",VOL) but same error.
Peter
