Local Time 05:43 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Win10 without internet
palcal
Posted: 08:37am 06 May 2020
Can I use a Win10 machine without having it connected to the internet ever. Since updates can't be turned off I wondered what would happen. I searched the net but couldn't find a definite answer. I want to use a laptop for a dedicated purpose and it wont have an internet connection.
KeepIS
Posted: 08:48am 06 May 2020
I've a tiny Win10 module PC running in my Vehicle for years, never complains about not having an internet connection, always runs normally.
Posted: 10:44am 06 May 2020
i've got a netbook running win10, the sole purpose of which is to create bootable bios updates that often require a windows machine. without internet access i can confirm it runs brilliantly, whereas once you let it touch the net is turns into an absolute dog!
rob   :-)
palcal
Posted: 08:40pm 06 May 2020
Good news, thanks.
Phil23
Posted: 09:47pm 06 May 2020
Only thing that will slow you up initially is finding where they've hidden the option to create a Local User Account instead of an online MS Account.
They seem to find a different hiding place from time to time, ESPECIALLY in the case of Home & S Editions.
Win10 Pro seems a lot more straight forward in that respect.
BrianP
Posted: 09:52pm 06 May 2020
  palcal said  Can I use a Win10 machine without having it connected to the internet ever. Since updates can't be turned off I wondered what would happen. I searched the net but couldn't find a definite answer. I want to use a laptop for a dedicated purpose and it wont have an internet connection.
Win 10 runs fine if you don't let it phone home...
(edit)
You actually CAN turn updates off with a registry tweak.
WAU Manager.zip
This handy little program will put you in control (Until MS decides they don't like it... )
B
Edited 2020-05-07 08:28 by BrianP
Herry
Posted: 02:18am 07 May 2020
Just be sure that you've set it to local. And stay clear -- whatever you do -- of Office 365!
Senior?!  Whatever it says, I'm a complete and utter beginner...
palcal
Posted: 02:39am 07 May 2020
Thanks for all the replies, I'll see how it goes.
MustardMan
Posted: 11:07am 08 May 2020
I didn't think that Win10 could even be installed without an internet connection! Goes to show how much I (don't) know.
Where would I find an offline Win10 installer? One that doesn't need to "internet" to download "drivers" for even the most common hardware? Is it simply a matter of selecting a particular version? eg: home, vs pro, vs corporate, vs embedded, vs ...god-knows-how-many-variants-ms-has!...
Cheers,
palcal
Posted: 08:59pm 08 May 2020
From what I see you just install normally but when it asks for a Microsoft account you skip this and open a local account instead. Have a look on the web I found heaps there about it.
BrianP
Posted: 10:53pm 08 May 2020
  palcal said  From what I see you just install normally but when it asks for a Microsoft account you skip this and open a local account instead. Have a look on the web I found heaps there about it.
FWIW what I've found the best way to install W10 is to disconnect from the Internet once you have downloaded your install package. Otherwise you will have to go through hoops to bypass the "MS Account" garbage. Once you have successfully set up an "offline" i.e. "local" account you can re-establish your Internet connection for the rest of the drivers etc. setup.
One of the few kudos for Win10 is its native support for a very wide range of drivers. I hardly ever have to manually install a driver to enable a hardware item.
Mind you, YMMV.
B
