Local Time 03:50 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : using MMedit on Parallels(MAC)
TrevorH
Posted: 12:55pm 28 Mar 2020
TrevorH
Posted: 01:02pm 28 Mar 2020
I am sure this probably has been covered,
I have recently gone over to using Parallels with my Mac as the USB handling seems to WORK.
I am having a problem with MMedit, I can't load or save files as I get some sort of string error.
What do I have to alter in MMedit's setup to get out of this.
Trevor
TrevorH
Posted: 02:35pm 28 Mar 2020
@Tassyjim
Is this to do with network folders? the log shows mac folders NOT windows folders
Trevor
Posted: 09:24pm 28 Mar 2020
Never had a MAC so I am not much help.
What version of MMEdit?
By "USB handling seems to work" does that mean that the terminal works?
Can you be more helpful with "as I get some sort of string error."
"Is this to do with network folders? the log shows mac folders NOT windows folders"
Give me an example.
Can you load files directly from the edit window using load and run or from the terminal using "Load"?
TrevorH
Posted: 11:23am 29 Mar 2020
Hi Jim,
I am using V4.0.0.
What I mean with the USB thing, Parallel's seems to better at handling the USB ports, I was using VirtualBox before and found the usb ports didn't seem to be handled very well as I  could never connect to anything USB.
The error message I get with either load or save is "0  String can't hold String".
Here is the first few lines of the Configuration Report:-
12:05:06  Mar 29, 2020  OS Ver: 6.01
MM Edit Version: V 4.0.0  2020118131330
Build Date: 18-Jan-2020 13:13:30 UTC
Program folder: C:\Program Files (x86)\CCom\MMedit
Data folder: C:\Users\trevor\AppData\Local\CCom\MMedit
locate.inf:
DocsDir$ = \\Mac\Home\Documents
mainWinLoc$ = 1059 1291 6 11 80
configWinLoc$ = 479 411 478 272
chatWinLoc$ = 765 696 1071 9 1 1
CapDir$ = \\Mac\Home\Documents
fileWinLoc$ = 536 599 282 199
includeDir$ = \\Mac\Home\Documents
MMBdosEXE$ = \\Mac\Home\Documents
HintWinLoc$ = 688 300 602 160
ReportWinLoc$ = 690 499 584 39
Options$ = 1001111001210000000000000000000
FindWinLoc$ = 245 183 400 277 0 0
externalEXE$ =
autoBackup$ =
"Load and Run" works perfectly once I have code file in MMedit, which I can do thro' copy and paste from Notepad.
How can I change the paths of the MMbasic data files, If that is what is wrong???
Trevor
Posted: 09:07pm 29 Mar 2020
It is probably the UNC file names that are causing the problem.
Instead of "DocsDir$ = \\Mac\Home\Documents", can you map the network drive to a drive letter.
eg
"DocsDir$ = Z:\Home\Documents"
Alternatively, copy the files to a place within the windows file structure.
TrevorH
Posted: 12:30pm 30 Mar 2020
Hi Jim,
Thanks for your reply, is there away to set up the data directories when MMedit is setup as the config report does't have a save (I guess MMedit doesn't read this file anyway, only generates it)??
Have tried setting mac directories to windows directories using file manager's Map network dirs,
but didn't help.
Trevor
Posted: 09:05pm 30 Mar 2020
The config report is just that. A report.
Most of the settings are remembered from the last use rather than a configuration option.
You could try deleting the locate.inf file from the data folder. Maybe delete all the *.inf files.
Do this with MMEdit shut down and they will be recreated next startup.
TrevorH
Posted: 12:05pm 01 Apr 2020
Hi Jim,
I finally fixed the problem, by disconnecting all references in windows with the Mac in Parallels,
ie running windows on its own NO sharing, and re-installed MMedit.
Now running MMedit the Config Report now shows C:/users etc, etc as folders.
None of the other things suggested worked, but thanks anyway.
Trevor.
