Local Time 03:02 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dedicated Microchip USB to serial IC
HankR
Posted: 04:05am 11 Mar 2020
Quite a while ago a device was discussed here made by Microchip that is a USB to serial converter.
It actually consisted of a 16F1455 uP programmed at the factory to perfom that specialized USB function; it couldn't be unprogrammed.
Could someone tell me the Microchip part number?  Not having much luck navigating the Microchip website; certainly haven't been able to find this particular part.
Hank
Edited 2020-03-11 14:06 by HankR
panky
Posted: 05:27am 11 Mar 2020
Hi HankR,
Not sure about a PIC16F1455 actually provided by Microchip pre-loaded but there is a kit for a PIC16F1455 called the Microbridge that is a small USB to Serial adaptor. It was developed by Geoff and featured in the May 17 edition of Silicon Chip magazine.
One of it's great benefits is that it can also be used to program a Micromite - Graham Rixon (Grogster on the forum) can provide more info on how this is done but it is also covered in detail in the Silicon Chip article.
You can buy copies of the article, the blank board,as well as the pre-programmed PIC16F1455 from Silicon Chip at www.siliconchip.com.au
panky
Posted: 07:52am 11 Mar 2020
  Quote  Could someone tell me the Microchip part number?
MCP2221
CircuitGizmos
Posted: 04:51pm 11 Mar 2020
The chip can also be bought through CircuitGizmos:
http://circuitgizmos.com/gizmo-store/USB-to-serial-Pic32prog-programmer-interface-p69742387
Do you need it in a DIP package or SMT? I can send either.
Robert Rosee created the programming IDE wrapper for the chip. matherp compiled the hex file, I believe.
HankR
Posted: 07:47pm 11 Mar 2020
MCP2221
Thank you Peter.  That is exactly what I was looking for.
Thanks also to the other posters for the extra information about the 1455 which is of some interest to me for sure, but the 2221 specifically is for others to order by the hundreds for a DIY amateur radio project.
A PCB was designed that used a FTDI module and there is now a global shortage of those modules.  A new PCB for the project will design out the module and design in the 2221.
