Local Time 03:04 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GPIO voltage protection
helltek
Posted: 05:45pm 10 Mar 2020
What do you guys use for voltage protection on bi-directional gpio pin?
On single direction low speed I would use optocoupler.
What should I use on bi-directional 5 - 16 VDC I/O ?
panky
Posted: 05:16am 11 Mar 2020
Hi helltek,
For common ground referenced digital input in the range 5VDC to 16VDC, a simple 3.3V zener clamp would protect the input. If you need to go digital out to a 5VDC to 16VDC load, then a transistor or MOSFET driver would do the job.
If the input or output is to be a floating source/load, then an opto isolator would be required.
panky
PeterB
Posted: 07:51am 11 Mar 2020
G'Day both.
I think we need more detail about what is required. Opto isolation is very good for input and there are devices available to drive all sorts of outputs. Matherp has been flogging a nice sounding chip for that sort of thing but if you want to be able to control direction using software it will get messy. But nothing is impossible.
Peter
helltek
Posted: 09:02am 12 Mar 2020
The problem I see is that using transistor or optocoupler (which is transistor) I would create infinite loop. The input voltage would turn on the output transistor and never release it, probably shorting the peripheral and burning it out when it tries to switch low to high.
PeterB
Posted: 10:11am 12 Mar 2020
If you connect a 330 ohm resistor from a micro output pin to an external circuit the external circuit can be an input or an output. If the micro is set as output and the external circuit is an input it will work. If the micro is set as input and the external circuit is an output it will also work. That is however, not real good. It can be improved by adding diodes to prevent the micro from being over-voltaged but it is still far from ideal.
Is that something like what you are looking for?
Peter
Edited 2020-03-12 20:12 by PeterB
helltek
Posted: 10:28am 12 Mar 2020
330 ohm would limit current to about 10mA which is quite high. Safe current for TTL logic is about 2-3mA and that would be to low to pull the output down to zero volts. It would hang somewhere in between 0 and 3.3V, not being recognized as either 1 or 0.
Take as an example Maxim Dallas 1-wire communication. It works because the micro has 5V tolerant pin. If the signal was 12V, that would require voltage level converter like serial RS-232 to TTL and two pins (input pin and output pin).
I'm not sure if there is any way to make it work reliably.
PeterB
Posted: 11:34pm 12 Mar 2020
Sorry helltek but I don't think I can contribute anything of use. Perhaps some of our smarter members can help.
Peter
Posted: 12:07pm 13 Mar 2020
Dear Helltek,
There are 2 common type of opto couplers, and some less common types.
The common types are :
LED-Phototransistor optocouplers (i.e. TIL111).
These optocouplers are cheap, and over a large range exhibit a analog behaviour. Main parameter involved is the CTR (current transfer ratio). This is the gain (in current) of the opto coupler.
If you drive the LED with 2mA, and have a CTR=100(%), the phototransistor will draw 2mA. If you drive 10mA, the phototransistor will draw 10mA.
Check the datasheet of your optocoupler to find the CTR (or CTR range). Sometimes it is 50%...200%, in which case you should calculate with 50%.. just to make sure.
To drive 2mA from a 3.3V digital output you need a series resistance of roughly 800 ohms.
To make sure the output of the optocoupler has a logic output (well saturated) at 2mA, -- note ..this assumes a CTR of 100%) design the pullup resistor for 25% of the 2mA (0.5mA). Using 5V logic, the resistor should be (5/0.0005 = 10k).
The list of optocouplers of this type is endless. They are the most common. Differences are in:
1/ CTR
2/ isolation voltage (i.e. 3750V)
3/ immunity (CMRI) i.e. 5000V/uSec)
4/ Package (SMT/TH)
5/ minimum LED current
6/ max voltage for output transistor
7/ isolated base of output transistor / base connected to pin
LED-digital optocouplers
These optocouplers have build in schmitt triggers (comparator). These have fixed analog bias and threshold. Therefore you must drive the LED of these optocouplers exactly as described in the datasheet. These optocouplers have logic outputs.
The classical digital optocouplers (i.e. 6N136) require quite a bit of LED drive (i.e. 10mA). But the more modern ones (i.e. TLP2745) require only 2mA and can be driven directly from logic.
Other optocouplers:
- MOSFET output optocouplers (directly drive a FET, no isolated power supply is needed). Typically these MOSFET's optocouplers are not fast or powerfull.
- Ananlog optocouplers (2 or 3 identical optocouplers designed for analog isolation in combination with an external opamp).
Then there are digital isolators
These are typically used for isolating high speed signals. Multiple channels per package. They use capacitive or inductive coupling (not optic) and use modulators/demodulators in each channel.
I hope this helps
