Local Time 03:02 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MX470  + LCD 20X4
kermess
Posted: 07:20pm 16 Feb 2020
Hi...
I want to mount a PIC32MX470F512H-I/PT 64 pins and mount a 20X4 LCD display.
Question, can I connect it normally to the lines marked as SSD1963 for example D0, D1, D2 ... etc. and that the system works ... ???
Thank you.
David Perez
Posted: 09:35pm 16 Feb 2020
Yes you can.
The pins marked for the SSD1963 only become reserved when you use the command OPTION LCDPANEL SSD1963_x
kermess
Posted: 06:59am 17 Feb 2020
Hi.
Thank you very much from Barcelona.
David Perez
