Local Time 00:46 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ CPU  Speed TIME$ Anomaly
panky
Posted: 10:30am 24 Dec 2019
On a 470 Micromite running MMBasic 5.05.02, when the CPU is set to 5MHz, the timer and time$ functions run fast with time$ gaining about 11 seconds per minute.
All other CPU speeds appear OK. Has anyone else seen this problem?
Code below was used to test -
SETTICK 60000, tickint
CPU 5
DO
LOOP
SUB TICKING
 PRINT "Time is -", TIME$
END SUB
Comparing with a known correct time, the MM thinks it is interrupting every 60 seconds but in fact does so every 48 or 49 seconds with the MM+ thus having the wrong time.
panky.
Posted: 01:45pm 24 Dec 2019
That sounds like a serious issue.  I will setup a test rig and report back.
