Local Time 23:34 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Winbond Flash memories revisited
Posted: 07:51pm 24 Nov 2019
re-post in new topic due to age of the related thread (thanks to a BS member that pointed out the original thread was 4 years old next stop)
Just a note to say there is a code-pack for Reading/Writing Winbond flash memories now in the library here: http://fruitoftheshed.com/MMBasic.MMBasic-code-pack-to-Read-and-Write-Winbond-Flash-Memories.ashx
This is a pure MMBasic solution (no CSubs/CFunctions) so MMX and ArmMite users can now enjoy these fantastic little chips. The code has been tested on 4 and 8MB devices and I will check other chips as they arrive (16MB on order)
enjoy
Tinine
Posted: 07:57pm 24 Nov 2019
Great stuff, Cap'n!
I was about to ask about the supported capacities but you already just covered it.
Many thanks!
Craig
Tinine
Posted: 11:08am 25 Nov 2019
@Cap'n
Are you using the bare device or one of those eBay-type modules?
Craig
Posted: 12:42pm 25 Nov 2019
Can't remember where I got them from but I have a strip of bare chips.
My test setup for this code was one of my Mk5 '170 controller boards with the Flash on-board but BigMick has been testing the same code on his MMX BackPack64x boards in Oz... with enviable speed differences
If it helps I can send you a bare PCB and you can build up the same as I have here, PM me if you want to reproduce this same test board.
regards
Edited 2019-11-25 23:09 by CaptainBoing
Tinine
Posted: 09:49pm 25 Nov 2019
Offer much appreciated, sir but I need to resist. I believe that I already hold the world record for the number of times that a H7 has been unpacked/repacked
Trying to stay focused on the 2nd E100 project....had a weak moment today and drifted on to the Micromite.org site and ordered another MX170 module..aarrgh!
Darn you Geoff & Pete
Posted: 10:00pm 25 Nov 2019
hooked!
If you snag one of those break-out modules on ebay, you can play with the Windbond Flash on all those platforms with the same code
Edited 2019-11-26 08:02 by CaptainBoing
