Local Time 22:31 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4 Distance Measurements
Chopperp
Posted: 10:51am 10 Nov 2019
Hi (matherp?),
I've just hooked up a HC-SR04 ultrasonic sensor to an F4 (Latest update) & it is measuring in inches rather than cm.
Just using "print DISTANCE(trig, echo)" (pc3, pc2) in a one second loop.
Not really a problem. Multiplying the result by 2.54 gives the metric value. (quite accurately BTW).
Just wondering if I've missed something. (I've previously had it running on a 44 pinner with no problems)
Brian
ChopperP
