Local Time 22:30 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI question
Tinine
Posted: 01:00pm 08 Nov 2019
Haven't done much with SPI and I RTFM but am still confused:
So this following code works well and MSB comes first. I then sum the bytes to get a 32bit "Count"...
SPI OPEN 10000000, 0, 8 ' speed is 10MHz and the data size is 8 bits
PIN(69) = 0 ' assert the enable line (active low)
junk = SPI(&H60) ' send the command and ignore the return
byte1% = SPI(0) << 24 ' get the first byte from the slave
byte2% = SPI(0) << 16' get the second byte from the slave
byte3% = spi(0) << 8
byte4% = spi(0)
Count% = byte1% + byte2% + byte3% + byte4%
PIN(69) = 1 ' deselect the slave'
Reading about the "Bulk Read", as an option, it suggests loading the bytes into an array...I would still need to build the required 32bit value.
Is it possible to OPEN as 32 bits and simply read directly into a MM integer?:
SPI OPEN 10000000, 0, 32
Posted: 03:03pm 08 Nov 2019
Yes and no obviously
At least on the Armmites you can open for 32-bit and it will read into an integer. However, in your example, this would also send the &H60 as a 32-bit transmission which would almost certainly bugger things up.
The better way of doing it is to use STR2BIN on the input string - check the ArmmiteH7 or MM(+) manual for details - deals with big-endian, little endian and different string sizes
