Local Time 22:30 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DUINOMITE BME280
kiaandre
Posted: 01:47pm 31 Oct 2019
Bonjour
Je cherche le code (MMBASIC 4.5) pour faire fonctionner le BME280 sur un Duinomite Mega
J'ai recherché sur le net mais rien ......
Merci par avance
Quazee137
Posted: 09:08pm 31 Oct 2019
Have a look here
Regardez ici
At Adafruit
More at Adafruit
and at randomnerdtutorials
Edited 2019-11-01 07:29 by Quazee137
PeterB
Posted: 08:25am 01 Nov 2019
G'Day (Bonjour) (Hi)
To my great shame I gave up and used Arduino.
1. I just wanted to see how well they work and
2. I figured I could pass my data over to a PIC or whatever if needed.
I know, I'm a coward
Peter
kiaandre
Posted: 08:35am 01 Nov 2019
HELLO
HE YES, I AM STILL ON A DUINOMITY (PIC32MX and in MMBASIC 4.5)
, I find for the BMP180 but I hold on the BME280, if you could help me, I thank you in advance
(by GOOGLE Translation) - THANK YOU
PeterB
Posted: 09:50am 01 Nov 2019
I have been looking at the BME280 data.
I am now in a state of shock.
I remember when I looked at the thing some time ago I didn't like it.
I think use an Arduino to extract the data and than send it to the PIC. The Arduino nano is a nice little device. The alternative is insanity.
I could be wrong. Quarzee is a very clever bloke so he may come up with a clever idea.
Peter
kiaandre
Posted: 10:02am 01 Nov 2019
I heard about the conversion of Arduino code to PIC, but I'm skeptical about the result, the other solution is to find the code an I2C humidity sensor that works on DUINOMITE MMBASIC 4.5
Posted: 10:08am 01 Nov 2019
Have you tried converting this
PeterB
Posted: 10:24am 01 Nov 2019
Kiaandre
Do you only need humidity?
Peter
PeterB
Posted: 10:53am 01 Nov 2019
option explicit
option default none
'  BME280 routines and test harness
const BME280_ADDRESS                    = &H77
const BME280_REGISTER_T1                = &H88
const BME280_REGISTER_P1                = &H8E
const BME280_REGISTER_H1                = &HA1
const BME280_REGISTER_H2                = &HE1
const BME280_REGISTER_CHIPID            = &HD0
const BME280_REGISTER_CONTROLHUMID      = &HF2
const BME280_REGISTER_CONTROL           = &HF4
const BME280_REGISTER_PRESSUREDATA      = &HF7
const BME280_REGISTER_TEMPDATA          = &HFA
const BME280_REGISTER_HUMIDDATA         = &HFD
dim integer s16=&HFFFFFFFFFFFF0000 , s16b=&H8000
dim integer s12=&HFFFFFFFFFFFFF000 , s12b=&H800
dim integer s8= &HFFFFFFFFFFFFFF00  , s8b=&H80
DIM INTEGER T1,T2,T3     'uint16_t, int16_t, int16_t
DIM INTEGER P1,P2,P3,P4,P5,P6,P7,P8,P9    'uint16_t, 8 x int16_t
DIM INTEGER H1,H2,H3,H4,H5,H6     'uint8_t, int16_t , uint8_t, int16_t, int16_t, int8_t
dim INTEGER t_fine  'used to store accurate temp reading from temp conversion for use in pressure and humidity conversions
'  Test program
bme280_init
do
 print bme280_read_temp()  'must be run before pressure or humidity
 print bme280_read_pressure()
 print bme280_read_humidity()
 pause 2000
loop
end
function  bme280_read_temp() as float
 local integer var1,var2,adc_T
 local adc%(2)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_TEMPDATA
 i2c read BME280_ADDRESS,0,3,adc%()
 adc_T=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
 var1  = ((((adc_T>>3) - (T1 <<1))) * T2) \ q(11)
 var2  = (((((adc_T>>4) - (T1)) * ((adc_T\ q(4)) - (T1))) \ q(12)) * (T3)) \ q(14)
 t_fine = var1 + var2
 bme280_read_temp = ((t_fine * 5 + 128) \ q(8))/100.0
end function
function  bme280_read_pressure() as float
 local integer var1, var2, adc_P, p
 local adc%(2)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_PRESSUREDATA
 adc_P=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
 var1 = t_fine - 128000
 var2 = var1 * var1 * P6
 var2 = var2 + ((var1 * P5)<<17)
 var2 = var2 + (P4 << 35)
 var1 = ((var1 * var1 * P3)\ q(8)) +    ((var1 * P2)<<12)
 var1 = ((1<<47)+var1)*P1\ q(33)
 if var1 = 0 THEN
   bme280_read_pressure =  0' avoid exception caused by division by zero
   exit function
 endif
 p = 1048576 - adc_P
 p = (((p<<31) - var2)*3125) \ var1
 var1 = (P9 * (p\ q(13)) * (p\ q(13))) \ q(25)
 var2 = (P8 * p) \ q(19)
 p = ((p + var1 + var2) \ q(8)) + (P7<<4)
 bme280_read_pressure = p/25600.0
end function
function  bme280_read_humidity() as float
 local integer v_x1,adc_H
 local adc%(1)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_HUMIDDATA
 i2c read BME280_ADDRESS,0,2,adc%()
 adc_H=(adc%(0)<<8) or adc%(1)
 v_x1 = t_fine - 76800
 v_x1=(((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))*(((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14)))
 v_x1 = (v_x1 - (((((v_x1 \ q(15)) * (v_x1 \ q(15))) \ q(7)) * (H1)) \ q(4)))
 if v_x1< 0 then v_x1 = 0
 if v_x1 > 419430400 then v_x1= 419430400
 bme280_read_humidity = (v_x1\ q(12)) / 1024.0
end function
sub bme280_init
 local i%,cal%(17)
 i2c open 400,1000 '400KHz bus speed
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_CHIPID
 i2c read BME280_ADDRESS,0,1,i%
 if i%<>&H60 then print "Error BME280 not found"
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_T1
 i2c read BME280_ADDRESS,0,6,cal%()
 T1=cal%(0) OR (cal%(1)<< 8)
 T2=cal%(2) OR (cal%(3)<< 8):   if T2 and s16b then T2=T2 OR s16 'sign extend if required
 T3=cal%(4) OR (cal%(5)<< 8):   if T3 and s16b then T3=T3 OR s16
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_P1
 i2c read BME280_ADDRESS,0,18,cal%()
 P1=cal%(0) OR (cal%(1)<<8)
 P2=cal%(2) OR (cal%(3)<<8):   if P2 and s16b then P2=P2 OR s16 'sign extend if required
 P3=cal%(4) OR (cal%(5)<<8):   if P3 and s16b then P3=P3 OR s16
 P4=cal%(6) OR (cal%(7)<<8):   if P4 and s16b then P4=P4 OR s16
 P5=cal%(8) OR (cal%(9)<<8):   if P5 and s16b then P5=P5 OR s16
 P6=cal%(10) OR (cal%(11)<<8):   if P6 and s16b then P6=P6 OR s16
 P7=cal%(12) OR (cal%(13)<<8):   if P7 and s16b then P7=P7 OR s16
 P8=cal%(14) OR (cal%(15)<<8):   if P8 and s16b then P8=P8 OR s16
 P9=cal%(16) OR (cal%(17)<<8):   if P9 and s16b then P9=P9 OR s16
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H1
 i2c read BME280_ADDRESS,0,1,H1
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H2
 i2c read BME280_ADDRESS,0,7,cal%()
 H2=cal%(0) OR (cal%(1)<< 8):   if H2 and s16b then H2=H2 OR s16 'sign extend if required
 H3=cal%(2)
 H6=cal%(6):   if H6 and s8b then H6=H6 OR s8 'sign extend if required
 H4=(cal%(3)<<4) OR (cal%(4) and &H0F): if H4 and s12b then H4=H4 OR s12 'sign extend if required
 H5=(cal%(5)<<4) OR (cal%(4)>>4):  if H5 and s12b then H5=H5 OR s12
 i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROLHUMID,&H05 '16x oversampling humidity
 i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROL,&HB7      '16x oversampling pressure/temp, normal mode
end sub
function q(x as integer) as integer  'returns 2 raised to the power
 q=(1<<x)
End CFunction
I found this. I have no idea where it came from.
Peter
kiaandre
Posted: 03:53pm 01 Nov 2019
The DUINOMITE uses the MMBASIC 4.5, the problem for example the syntax "Const" does not exist in version 4.5 of the MMBAIC which is the latest version of the material DUINOMITE, I think PeterB is not far from the goal - Thank you
kiaandre
Posted: 03:54pm 01 Nov 2019
PeterB
Posted: 11:51pm 01 Nov 2019
G'Day
You might have a look at SENSIRION SHT 30-ARP-B.
Peter
PeterB
Posted: 01:16am 02 Nov 2019
OOOPS
It's from Peter Mather. If I had read his post I'd have seen it.
Peter
