Local Time 21:23 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : programmein backpack v3 or v2 using pic32prog
BobDevries
Posted: 02:45am 28 Oct 2019
Hi all,
I recently bought a backpack V3 and tried to upgrade its micro.
pic32pro runs (win10), but I get the following error:
No response from ascii ICSP adaptor
and
No target found.
I have pic32pro and the hex file in the same directory (folder)
any suggestions?
Regards, Bob Devries
Dalby, QLD, Australia
Edited 2019-10-28 12:49 by BobDevries
Bob Devries
Posted: 03:10am 28 Oct 2019
Hi Bob,
Same response that fixed a similar problem for Greg.....
Have you put the pic16 into PROGRAM mode? (Momentarily short the 2 pin header and the led should light)
BobDevries
Posted: 08:54pm 28 Oct 2019
  bigmik said  Hi Bob,
Hi Mick.
Yes the backpack V3 has a push button switch and an LED. If I press the switch the LED lights but when pic32prog starts it goes out again and programming fails.. BTW the chip ia a PIC32MX170F-256B-501/SP
Does this have anything to do with the glitch on the MISO pin mentioned in Silicon Chip (August 19 pp 9?)
Regards Bob Devries
Bob Devries
Turbo46
Posted: 10:10pm 28 Oct 2019
The MISO 'glitch' is explained in the Silicon Chip May article and Peter Mather's post here. The offending signal is on pin 9 which is not connected so it is not the problem.
I suggest that you carefully check all of the PCB around the PIC16F1455 IC for dry joints, unsoldered connections and solder bridges. Remove and re-seat the IC and check for bent pins. Check the value of the 10k resister on the reset line (pin 7 of the PIC16F1455).
Also remove and re-seat the PIC32MX170F and check for bent pins.
Posted: 10:44pm 28 Oct 2019
hi,
   place a 10k pullup resistor from the 3v3 supply line to pin 11 of the pic32.
rob   :-)
Turbo46
Posted: 12:53am 29 Oct 2019
Thanks Rob.
Bob, do as Rob says before you try anything else. A quick search shows that this has occurred before and Rob's suggestion was the fix.
