Local Time 21:24 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Display
Fang_Bolt
Posted: 07:54pm 11 Oct 2019
After programming display ,the touch control is mirrored.
Any ideas anyone ?
Posted: 08:15pm 11 Oct 2019
More information needed. Which micromite, which display, which backpack or other additional PCB (if any). What does "the touch control is mirrored" mean?
Posted: 11:33pm 11 Oct 2019
Probably you loaded a HEX file from my site which contained MMBasic + config options + BASIC program.  The calibration of the touch was done with a reasonably "standard" LCD panel but your panel is different from my panel.
The solution is simple.  Attach a USB/Serial converter to the console.  Interrupt the running program with CTRL-C and re do the touch calibration using GUI CALIBRATE.
Fang_Bolt
Posted: 08:32pm 13 Oct 2019
Many Thamks
Fang_Bolt
Many Thamks
