Forum Index : Microcontroller and PC projects : UART TIMEOUT
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Can anyone help me? I am looking for a way to wait a certain time for characters of a serial interface, as it was realized with the PBP compiler for example: SERIN Pin,Mode,{Timeout,Label,} Does anyone have a code snippet for a timeout like this? Do I have to implement this via TIMER and LOC? Any help is appreciated! THANKS! Frank |
Frank, This may not be the most elegant way and does not cater for day over-run but it may give you some ideas. It is a blocking routine (that is, it loops internally for the timeout period). A neater solution would be to do something with flags. Option explicit dim S_Timeout,s_port print "Wait for 10 seconds then print all characters waiting in Rx buffer" ' example: call routine, wait 10 seconds then print all characters ' entered from console (s_port = 0) print SerIn$(10,0) function SerIn$(S_timeout,s_port) ' function to wait S_Timeout seconds from current time and ' return all characters waiting in Rx buffer of COM port s_port ' Note: this is a blocking routine local tout,start_secs,s_chars$ tout = S_timeout start_secs = T_now() do loop while T_now() < start_secs + tout s_chars$ = input$(255,s_port) ' will get up to 255 characters from com port SerIn$ = s_chars$ end function Function Time_now(arg1) ' arg1 unused ' returns current time in seconds, does not cater for day over-run local t_n t_n=(val(left$(time$,2))*3600)+(val(mid$(time$,4,2))*60)+val(right$(time$,2)) T_now = t_n end function panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
It depends a lot on the flow of the rest of the program. This routine uses the console as input but a serial port would be much the same. Instead of k$=INKEY$, use IF LOC(#1) > 0 THEN doKEY I choose to check for input in the main loop instead of using interrupts because the program is doing time critical things and I don't want them interrupted. SUB doKey is entered when there is at least one character available. It then loops through, gathering additional characters until there is a LF indicating end of data or empty k$ indicating data flow has stopped or more than 20 characters have been received because in this setup, that would be an error condition or there has been more than 500 * 2 mS The size of the delay needs to match the baud rate and take into account any delays in the sending device (such as manual key entry) Remove any condition tests that don't suit your data input method. Jim VK7JH MMedit |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
for serial time out Option EXPLICIT const maxto = 500 'exemple time out 5 sec dim cptto as integer 'count time$ dim flgeot as integer SETTICK 10,sptim Open "COM1:9600,255,spcomrec" As #2 flgeot=0 do ' if need to read serial cptto=maxto .... if flgeot=1 then flgeot=0 ..... 'task receive text end if ' ... 'if no need read serail cptto=0 loop sub sptim if cptto>0 then 'if cptto=0 then do nothing cptto=cpto-1 if cptto=0 then 'if end of time-out do task "timeout" .... end if end if end sub sub spcomrec Local tx$ As string Local i2 As integer Local a$ As string length 1 nbcar=Loc(#2) If nbcar>0 Then tx$=Input$(nbcar,#2) cptto=maxto 'do task read serial 'exemple For i2=1 To nbcar a$=Mid$(tx$,i2,1) If (asc(a$)=13 or asc(a$)=10) Then 'end rec texte ..... flgeot=1 end if next i2 end if end sub Edited 2019-09-23 18:19 by goc30 |
Many thanks to everyone - I will try it! Frank |
| PicFan Senior Member Joined: 18/03/2014 Location: AustriaPosts: 133 |
If I understood the problem correctly, an example with the console as input: SUB conINP(tm) TIMER = 0 DO WHILE((inp$ = "") AND (TIMER < tm)) inp$ = INKEY$ LOOP END SUB Maybe it,s help ? Wolfgang Edited 2019-09-23 23:25 by PicFan |
your code is good but not the best, bcause on return from your subroutine, you don't know why you come back. You must test inp$ to know, and remenber that timer work all time (and you can use timer on other sub) and for that an loop "do..while" with timer cond is not the more stable coding. I propose other code, with 2 more var in call: status return who say why you come back, and string var with key receive SUB conINP(tm,inp$,stat%) ' stat%=0 if sub in work (no timeout and waiting key$) ' stat%=1 if end on time-out ' stat%=2 if end on inkey buffer not empty and inp$=key$ local vtm as integer vtm = TIMER inp$ = "" stat% = 0 etq1: if TIMER - vtm > tm then stat% = 1: exit sUB inp$ = INKEY$ if inp$ <> "" then stat% = 2: exit SUB goto etq1 END SUB Edited 2019-09-24 00:39 by goc30 |
@ goc30 and PicFan: Thank you very much. Your last two solutions look very interesting - i will give it a try! Frank |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10081 |
You could also consider using the SerialRx C-function on any I/O pin, as it has a built-in timeout feature. r = SerialRx( pin, baud-rate, string$, timeout, maxchars, termchars) For example, r = SerialRx( 5, 9600, T$, 1000 ) will look for data for one second then return with whatever was received in T$. You need to DIM T$ before you call this. Here is the PDF for the Cfunction: SerialRx.pdf This works well, if you KNOW when to expect data, and then you go and look for it, or perhaps the data is continuously being sent with a delay between packets etc, and you just want to intercept the most current packet. Edited 2019-09-25 08:21 by Grogster Smoke makes things work. When the smoke gets out, it stops! |
Hi Grogster, that looks very interesting! I know exactly when the characters come (when they come) - and if they don't, I need the timeout. I will try it! I have to read out a barcode reader - and if it fails I have to start error handling. THANKS! Frank |
hi grogster I completely forgot about your solution which is, by far, the best for the mentioned problem |
