Local Time 20:25 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4: BLIT Read / Write not working
erbp
Posted: 12:43am 21 Sep 2019
@Matherp
I have an Armmite F4 connected to an East Rising 9" LCD. I am trying to use the BLIT READ and BLIT WRITE commands but all they do is report 'Error: Syntax'. The BLIT CLOSE command also reports the same error - I would expect it to report an error in my test case as buffer #4 was never opened, but it shouldn't be a Syntax error!
> BLIT READ #4,100,100,50,50
Error: Syntax
> BLIT WRITE #4,300,100,50,50
Error: Syntax
> BLIT CLOSE #4
Error: Syntax
> BLIT 100,100,300,100,50,50    << This format (BLIT copy) works
I am running F4 Firmware version 5.05.08, as released in the 2019-08-13_222508_ArmmiteF4.zip on August 13.
Cheers,
Phil.
Posted: 11:03am 23 Sep 2019
BLIT READ and BLIT WRITE aren't currently implemented on the Armmite H4. I'll include them with the LOC bug fix
