Local Time 19:23 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Interface to Explore-28
envirotronics
Posted: 09:18am 11 Sep 2019
Explore-28 uses Pins 4& 5 to talk to USB-Serial interface.
I need these PINS to connect to the LCD
Will this be a problem?
Posted: 02:58pm 11 Sep 2019
pins 4 and 5 are only used for programming a new copy of the mmbasic firmware into the mx170. when this is not being performed, the pins are tri-stated at the 1455 and so can be used for any other purpose (like driving an LCD). the only problem you may have is if you later want to upgrade the firmware on the E-28.
i would suggest having either the LCD socketed, or a pair of jumpers you can remove if needsbe. however, provided pins 4 and 5 both run to input pins on the LCD, it is possible the presence of the LCD will not impact re-programming the firmware.
rob   :-)
palcal
Posted: 09:11pm 11 Sep 2019
I made an adaptor PCB, I may still have some.
See this post half way down. here
envirotronics
Posted: 11:37pm 11 Sep 2019
  robert.rozee said  pins 4 and 5 are only used for programming a new copy of the mmbasic firmware into the mx170. when this is not being performed, the pins are tri-stated at the 1455 and so can be used for any other purpose (like driving an LCD). the only problem you may have is if you later want to upgrade the firmware on the E-28.
rob   :-)
Thank you Rob,
Much appreciated
Graham
