Forum Index : Microcontroller and PC projects : Touch cannot be calibrated with loadable driver MM+ v5.5.02
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
I have a loadable driver for an ILI9341_P16 from sometime ago, was working on 5.1 last time I used it. I upgraded to 5.0502 beta6 and reloaded the driver. The screen works OK to display. The OPTION TOUCH 51, 33 is accepted, but when GUI CALIBRATE is tried it returns Display not configured, so can't be calibrated, and GUI INTERRUPT also returns Display not configured. I figured it must be looking for a display type , which the loadable driver is not setting. I entered OPTION LCDPANEL USER, 320, 240 and it then allowed GUI CALIBRATE (Its actually a CSUB driver) and error about MM.DRAWRECTANGLE not found (something like that) was returned initially but the touch is now working with the loadable driver Does a loadable driver now need to set a display type or something in the initalisation that was not previously required? > option list OPTION LCDPANEL USER 0, 0 OPTION TOUCH 51, 33 GUI CALIBRATE 0, 3786, 3745, -916, -681 Gerry Edited 2019-08-14 23:07 by disco4now F4 H7FotSF4xGT |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12085 |
Yes I've updated some of my drivers but I'm sure I will get reports of this ![]() Just include: Option->DISPLAY_TYPE=20; somewhere in the driver initialisation Edited 2019-08-15 00:43 by matherp |
