erbp Senior Member Joined: 03/05/2016 Location: AustraliaPosts: 195
Posted: 06:04am 13 Aug 2019
I guess this is one for @matherp.
When using the ARC command on an ARMmite F4 (Ver 5.05.08) I am getting an extra pixel displayed. It appears to be at the top left corner of the imaginary square enclosing the circle that the arc is a part of. I have tried a couple of F4 modules and different LCD panels, but the results are always the same. See below image for an example. These arcs were drawn using the following 3 commands:
As I'm not sure how well the single pixel points will show up in the image I have circled where they are and drawn a link to which arc each is associated with.
Could you please take a look at this?
Thanks, Phil.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12085
Posted: 08:17am 13 Aug 2019
Stupid boundary condition error - will fix in the next release
Posted: 11:17am 13 Aug 2019
Thanks!
Phil.
Posted: 10:51am 14 Aug 2019
Confirming that the 2019-08-13_222508_ArmmiteF4.hex firmware fixes the issue with the unwanted pixels.
