Local Time 12:56 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : generating pulses
Quazee137
Posted: 10:50am 22 Jun 2019
I am using a 170 Backpack to test a controllers inputs.
Trying to simulate a pumps racing relay that goes from
30PPM to 12000 PPM. My first thought was the pulse command.
But I can't get the pulse command working as I though it should.
setpin 17,1000 should be sending a 1 sec wide pulse out until
I change it. Right ???
For now I am using settick and toggling with pin(17)=not pin(17).
I read + - on LCD and settick to half the pulse width and loop.
The idea here is to use the 170 backpack as a hand held tester.
I have 4-20ma in and out working. Voltage meter 0 to 50VDC.
WIP With an adjustable up converter to output 0 to 24VDC from two
batteries. And four optocoupler inputs shared with four SSR outputs.
IT's fun watching a BIG (4-20ma) valve open and close while sliding
a finger across the LCD.
A 2nd though has been for a breadboard companion with Freq in/out
volt/current meter,8 inputs/outputs with just the 28 pinner.
These are projects that I'll post code and boards for when I get
them debugged and tested.
After my current project putting a mite in a din rail box to add
extended functions to a controller. Oh so many ideas here for later.
What do you thnk the best way to read PPM? I am playing with "COUNT"
and "PIN". "COUNT" is working but "PIN" takes time to be valid.
Quazee
Good got back in time to add this
Print "DualPumpSIM.bas"
'21/06/2019 Quazee"
Color RGB(black),RGB(white)
CLS
Font 1,4
SetPin 15, INTL, findkey ' touch interrupts pin
SetPin 15, inth, getkey
SetPin 17,dout 'sim pump 1 out
SetPin 18,dout 'sim pump 2 out
Pin(17)=0
Pin(18)=0
' 2000ms is 30 PPM so 1000ms per pulse half high... half low
' | 1000 | 1000 | 2000 |
s7=1000 ' v_______v v_______ v______
s8=1000 '_____| |_______| |______|
SetTick s7,p7,1
SetTick s8,p8,2
Font 1,5
Text 220,10,"-"
Text 270,10,"+"
Text 220,100,"-"
Text 270,100,"+"
Font 1,4
Text 5,100,Str$((1000/(s8*2)*60),1,2)+" "
Text 5,10,Str$((1000/(s7*2)*60),1,2)+" "
'Box 10,65,300,30,5
'Box 10,155,300,30,5
Text 0,210,"30 50 80 100 200",,1,2,RGB(blue),RGB(green)
' + - adjustment
If sy=0 Then
Select Case k$
Case "4"
s7=s7+(10*(s7<1100))
SetTick s7,p7,1
Case "5"
s7=s7-(10*(s7>150))
SetTick s7,p7,1
Case "6"
s8=s8+(10*(s8<1100))
SetTick s8,p8,2
Case "7"
s8=s8-(10*(s8>150))
SetTick s8,p8,2
End Select
k$=""
End If
' coarse adjustment
If sy Then
Select Case sx
Case 1
s7=1000
s8=1000
Case 2
s7=600
s8=600
Case 3
s7=375
s8=375
Case 4
s7=300
s8=300
Case 5
s7=150
s8=150
End Select
SetTick s7,p7,1
SetTick s8,p8,2
sy=0:k$=""
End If
'bit togglers
Sub p7
Pin(17)=Not Pin(17)
Sub p8
Pin(18)= Not Pin(18)
'crude inputs
Sub findkey
tx=Touch(x):ty=Touch(y)
If tx=-1 Then Exit Sub
If ty=-1 Then Exit Sub
kx=tx\50:ky=ty\50
key = kx+ky
sx=1+tx\64:sy=ty>200
Sub getkey
k$=Str$(key)
Edited by Quazee137 2019-06-23
Posted: 12:52pm 22 Jun 2019
  Quote  What do you thnk the best way to read PPM? I am playing with "COUNT"
Like all frequency counters SETPIN n,FIN has a gate time which, for the Micromite, defaults to 1 second. This can be changed - see the manualEdited by matherp 2019-06-23
