Local Time 12:57 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite firmware on Geoff’s Site
viscomjim
Posted: 11:44pm 12 Jun 2019
I just downloaded 5.0501 from Geoff's website, used pickit 3 to load (all good), loaded a known working program and it does not run at all. Weird output and crash. Then downloaded the latest from the archive area 5.04.09 and everything runs fine and dandy. Can someone try the newest version from the website out? I tried downloading it twice with exactly same results. This is on a 28 pin uMite.
viscomjim
Posted: 11:52pm 12 Jun 2019
Just tried again and remembered something about option autorun on and var save being used in the program. So if I type in var clear in the command line then hit run, all is good. This is somewhat strange...
EDIT...
The var clear has to be typed in the command line right after programming mmbasic into the chip. Once that is done, the program runs. But if that is not done and the program is run, it will crash very strangely. Edited by viscomjim 2019-06-14
PeterB
Posted: 12:23am 13 Jun 2019
Good morning
If you look back to Jan 24 (ish) we had a lot of trouble with that. V5.05.01 has a problem which can be cured by your method.
Grogster was the last bloke to get caught by it
Peter
