Local Time 10:44 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SpinBox
KeepIS
Posted: 10:03pm 16 May 2019
I notice the following effect with an interaction between some GUI controls and a Message Box, but mainly the Spinbox. If the Spinbox is touched and a Message box opens before the Spinbox Touch is released, the spinbox partly locks.
In the Simple code below, the "Change" button switches between a Control Touch press being acknowledged by Touch down or Touch up, it starts with Touch up and this allows the Spinbox to run correctly.
Arm H7 - Latest MM.Basic release from Geoff and Peter, but it's been there for a long time.
Using Touch UP as the Button Press detect solves the problem. But surely I'm not the only one who has noticed this, it's the same on all my H7 units and the E 100+.
CLS
DIM integer ButtonTouched,Change,Res
Const SBOX = 5
Const BT_ReStart = 6
Const BT_Change = 7
GUI SPINBOX SBOX,MM.Hres/20,MM.Vres/2,MM.Hres/3,MM.Vres/6,RGB(WHITE),RGB(BLUE),1,1,5
GUI BUTTON BT_ReStart,"Restart",MM.Hres/1.4,MM.Vres/2,MM.Hres/5,MM.Vres/6,RGB(WHITE),RGB(BLUE)
GUI BUTTON BT_Change,"Change",MM.Hres/2.2,MM.Vres/2,MM.Hres/5,MM.Vres/6,RGB(WHITE),RGB(BLUE)
GUI Interrupt TouchDN,TouchUP
Sub TouchDN()
IF Change Then ButtonTouched = Touch(REF)
Sub TouchUP()
IF NOT Change Then ButtonTouched = Touch(LASTREF)
DO
IF ButtonTouched <> 0 Then HandleTouch()
SUB HandleTouch()
Local as Integer ThisTouch
ThisTouch = ButtonTouched
Select Case ThisTouch
Case SBOX
Res = Msgbox("ERROR from something","OK")
Case BT_ReStart
CPU RESTART
Case BT_Change
if Change = 1 then
Change = 0
GUI Bcolour RGB(BLUE),BT_Change
else
Change = 1
GUI Bcolour RGB(RED),BT_Change
endif
Pause 500
End Select
ButtonTouched = 0
END SUB
Edited by KeepIS 2019-05-18
Posted: 01:01am 17 May 2019
Thanks, this could be a hard one to fix as the gui controls and the message box work in different ways. I will add it to the list for some serious thought.
KeepIS
Posted: 01:15am 17 May 2019
Thanks Geoff, although it's not a big deal once you are aware of the cause. Apart from GUI Hide, everything is just great, I'm running 187 GUI controls and 14 GUI Pages so eventually some obscure hiccup is likely to pop up, but MMBasic is still so dam stable.
Mike.
