Local Time 10:47 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with GUI HIDE?
seco61
Posted: 04:51am 12 May 2019
Hi.
I am having an issue with a control not being hidden when I show the page it is located on.
While displaying PAGE 1 (the default), I am creating a GUI Displaybox control (6) on PAGE 2 (GUI Setup 2). I am issuing the GUI HIDE command for this control.
When I show the page with the PAGE 1,2 command, the control is not hidden...
I have tried this on both a Micromite Plus v5.05.02 and an ARMmite H7 v5.05.06.
Cut down code below:
if mm.device$="Micromite Plus" then
' Definitions for the Micromite Plus LCD Backpack
cpu 120
pwm 2,1000,25
elseif mm.device$="ARMmite H7" then
' Definitions for the ARMmite H7
backlight 25
else
? "Device is not a Micromite Plus or ARMmite H7 - Found: "+mm.device$
error "Not a Micromite Plus or ARMmite H7!!"
endif
InitPages
page 1,2
' subroutine to create display pages
sub InitPages
cls
font 1,2
colour RGB(white)
gui setup 1
gui area 1,0,0,155,200
gui area 2,165,0,155,200
gui setup 2
gui area 3,2,198,156,42
gui area 4,162,198,156,42
gui displaybox 5,0,162,210,32,rgb(white)
ctrlval(5)="Total: 0.000"
gui displaybox 6,220,162,99,32,rgb(white),rgb(red)
ctrlval(6)="Disc"
gui hide 6
end sub
Gerard (vk3cg/vk3grs)
KeepIS
Posted: 09:11am 12 May 2019
I didn't think you could show two pages with the command
[code]
page 1,2
[/code]
Should that not be:
[code]
Page 1
Page 2
[/code]
Of course I could be missing something?
Or is this just your cutdown command?
I have numerous pages and am hiding/unhiding over a dozen controls on some pages on the fly on the H7 Edited by KeepIS 2019-05-13
seco61
Posted: 11:42am 12 May 2019
Hi.
According to the manual:
PAGE #n [,#n2, #n3, etc]
This will switch the display to show controls that have been assigned (via the
GUI SETUP command) to the page numbers specified on the command line
(#n, #n2, etc). Any controls that were displayed but are not on the current list
of pages will be automatically hidden.
Any controls on a page that was displayed on the old screen and is also
specified in the new PAGE command will remain unaffected.
The default when a program starts running is PAGE 1 and GUI SETUP 1. This
means that if these commands are not used the program will run as normal
showing all GUI controls that have been defined.
See also the GUI SETUP command.
KeepIS
Posted: 10:02pm 12 May 2019
OK, you obviously have a reason to hide/show/manipulate controls from various pages for displaying controls from a number of pages at the same time on screen, hope you get it sorted.
I'm more a "kiss" kind of coder as it suites my nature Edited by KeepIS 2019-05-15
seco61
Posted: 10:19pm 13 May 2019
Some additional information.
The GUI HIDE command does not appear to work when issued while the page the control is on is not active.
But the GUI SHOW command works in this case...
More sample code:
option default none
option explicit
option base 0
cpu 120
pwm 2,1000,25
backlight 50
else
endif
InitPages
page 1
pause 2000
page 2
pause 2000
page 1
pause 2000
page 2
gui hide 6:ctrlval(5)="Page 2 - hidden"
pause 2000
page 1
pause 2000
page 2
pause 2000
page 1
gui show 6:ctrlval(5)="Page 2 - showing"
pause 2000
page 2
pause 2000
page 1
pause 2000
page 2
sub InitPages
cls
font 1,2
colour RGB(white)
gui displaybox 1,0,22,210,32,rgb(white)
ctrlval(1)="Page 1"
gui setup 2
gui displaybox 5,0,162,320,32,rgb(white)
gui displaybox 6,0,198,99,32,rgb(white),rgb(red)
ctrlval(6)="Disc"
end sub
KeepIS
Posted: 10:41pm 13 May 2019
This has been the way it has always worked, well for me at least.
I assumed that once a Page command - PAGE X - was issued, that all controls
would be enabled, even if previously disabled.
I have a Page with 25 GUI Buttons and 1/3 of the Buttons occupy the same position as another buttons.
Logically I have to issue:
A: Page X command - which resets all controls to enabled.
B: GUI HIDE ALL
Then, depending on the current machine state, enable the required controls.
C: GUI SHOW Bx,Bx,Bx,Bx,Bx etc.
I have reread Geoff's Manual entry you quoted, but it seems a tad ambiguous to me.
However I can see where it would be handy to Enable or Disable controls on a Page prior to switching to the Page.
Apology if this is not the behaviour you are enquiring about.
Mike.
seco61
Posted: 11:04pm 13 May 2019
Hi.
From the Micromite Plus manual (page 40):
It is perfectly legal for a program to modify controls on other pages
even though they are not displayed at the time. This includes changing the value
and colours as well as disabling or hiding them. When the display is switched
to their page the controls will be displayed with their new attributes.
I have confirmed that the problem only exists with GUI HIDE - GUI SHOW, GUI DISABLE and GUI ENABLE all work when issued for a control that is not on the active page(s).
KeepIS
Posted: 11:09pm 13 May 2019
Yes I should have been more clear, I can (and do) update Control values when the Page is hidden, but I cannot Hide Controls (as in my little example) prior to page switching.
Mike.Edited by KeepIS 2019-05-15
Posted: 09:13am 14 May 2019
Thanks Gerard, another bug found! At least they are getting more and more obscure.
I will add it to the list and fix it in the next version (probably a beta release).
