Local Time 10:47 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Turtle graphics
KeepIS
Posted: 06:25am 11 May 2019
This post is more about saying a very big thanks you to Peter (matherp) for the work he is doing on the ARM series. In particular (in this case) Turtle graphics.
When I first read the post about the addition, I placed the info aside for a rainy day as I remembered it from many (to many) years ago. I was having a problem visualising automated cutting control commands that I had coded for my ongoing project. I was testing the code on my workshop Machine itself and this was a royal pain.
I now had a reason to load Peters latest version of MM.Basic and use Turtle Graphics.
For something like this it is a Godsend, seriously, I was able to pop the Turtle into the same code that generated the X/Y cutter movement and generate a complete display of the finished interconnecting workpiece instantly on screen. Being able to input various cutting parameters and have an instant display of the result on screen is the icing on the cake. The Ease and speed of coding using these simple Turtle graphic commands is what was so impressive. I had fully finished Display Page, menu items and an perfect output on screen in under an hour.
On the H7, MM.Basic is just a brilliant implementation of not only Geoff's fabulous MM.Basic and Peters Port to the ARM series, but also the fantastic additions that he had added.
So once again thankyou Peter.
[code]
Lines of code: 6626, Total variables: 887
189009 bytes
> memory
Flash:
175K (45%) Program (6626 lines)
209K (55%) Free
RAM:
45K ( 9%) 441 Variables
44K ( 9%) General
402K (82%) Free
[/code]
And it still hasn't fallen over or missed a beat. Amazing
Mike.
