Local Time 03:50 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi-cromite V5.05.03
Posted: 03:25pm 01 May 2019
Please find attached a new release of firmware for the Pi-cromite (OS must be Raspbian Stretch or Stretch-Lite)
2019-05-02_011715_mmbasic.zip
2019-05-02_011750_Pi-cromite_Manual.pdf
It includes a new information function MM.INFO$() as well as "LIST FUNCTIONS" and "LIST COMMANDS". It includes new drawing commands POLYGON, ARC and BEZIER and some optimization of existing drawing commands. It fixes a bug in SPRITE SHOW when one or both of the coordinates of the top left corner are negative.
It also fixes a number of issues that occurred when a user defined function was called in the conditional test of a DO WHILE loop or in the parameters of a FOR-NEXT loop - thanks to Geoff for this fix.
Edited by matherp 2019-05-03
retepsnikrep
Posted: 09:04pm 01 May 2019
When I win the euromillions i'm def going to hijack you with an offer you can't refuse (sorry forum members) to work on my own pet vanity project for while . :)
oh well i can dream... Thanks for your incredible work... Edited by retepsnikrep 2019-05-03
Gen1 Honda Insights.
goc30
Posted: 09:11pm 01 May 2019
hi peter
I install this version
run prog test graf
all is ok (MM.info SPRITES Polygon, Lsts) except ARC and Bezier
system said "Display not configured"
this pb is not present if LCDPanel=ILI9481
Device type=Pi-cromite
Autorun = off
CPU Speed = 120000000
LcdPanel = HDMI
SDCard = Ready
Touch = Disabled
-function SPRITE aviable
I have tested with lcdpanel 1.3" with ST7789 driver
it accept driver but nothing on screen
is my config correct?
and on test 20 (text transparent) and sprites, it stop with sigHandler error (signal 11).it seems that pb come from no read function with SPI driver
OPTION LCDPANEL ST7789,L,22,13,24
Edited by goc30 2019-05-03
Posted: 09:01am 02 May 2019
Please try this update. Fixes arc and bezier with HDMI, fixes sighandler error with ST7789.
2019-05-02_190134_mmbasic.zip
The config is correct for the version of the ST7789 I use
goc30
Posted: 09:42am 02 May 2019
Hi peter
as all time, very good job
I give you results
1 - For St7789: Sprite ok (I must modify my prog to windowing sprites in 240x240 res)
1bis - config is correct with 22,13,24 (as you put on your link)
2 - For HDMI: all is ok else.. triangles, i have nothing
3 - for ILI9481 config is different (18,22,24 and 10.000.000)
3b- all is ok, but it is very very very slow (167sec for all tests, and 27sec for minima - st7789 give 4sec for minima and 27sec for all)
(ili9481, is an 3.5" B v2)Edited by goc30 2019-05-03
Posted: 11:19am 05 May 2019
New version with STR2BIN() and BIN2STR$()
2019-05-05_211935_mmbasic.zip
ceptimus
Posted: 07:21pm 22 Aug 2019
I'm trying to get this going on a Raspberry Pi Zero W starting with a clean install.
My first mistake ? was probably installing Raspbian Buster Lite and then doing a sudo apt-get update and sudo apt-get upgrade.
Then I tried to install PigPIO 68 but could only find the newer V71.  Installed that which seemed to go mostly okay except it complained about a missing loader at the end - I think that was a Python 3 thing so I pressed on.
(here's the error)
if which python3; then python3 setup.py install ; fi
/usr/bin/python3
Traceback (most recent call last):
 File "setup.py", line 3 in <module>
   from distutils.core import setup
ModuleNotFoundError: No module named 'distutils.core'
make: *** [Makefile:107 install] Error 1
...but doing
sudo ./x_pigpio
...it passes all the (numerous) tests.
Installed the latest mmbasic from the previous post in pi's home directory and chmod +x'ed it
When I try sudo ./mmbasic I get:
./mmbasic: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
I've tried ldconfig -v | grep -i 'libncurses' which finds the following three instances
libncursesw.so.6 -> libncursesw.so.6.1
libncurses.so.6 -> libncurses.so.6.1
libncursesw.so.5 -> libncursesw.so.5.9
Any advice gratefully received.
Edited 2019-08-23 06:28 by ceptimus
Posted: 09:45pm 22 Aug 2019
Current versions of Pi-cromite are incompatible with Buster. You could try the attached but untested
mmbasic.zip
ceptimus
Posted: 07:47am 23 Aug 2019
Thanks Peter. That's working!
First time I tried it, I forgot the sudo, and got stuck with some text message scrolling up the screen - too fast to be readable: Ctrl-C, Ctrl-Break, and such wouldn't stop it, but Ctrl-Alt-Delete rebooted the Pi.
Second time I tried it, I saw:
LINUX MMBasic Version 5.05.04
Copyright 2011-2018 Geoff Graham
Copyright 2011-2018 Peter Mather
> print mm.ver
5.0504
I guess you could change your Copyright message to 2019
I shall now proceed to experiment.
Posted: 01:55pm 01 Apr 2020
I was getting "bad gpio" messages on my pi-ZW when starting "sudo ./mmbasic". I loaded the latest (I think) pi-cromite from this thread:
I'm still getting "bad gpio" and when I enter (no prompt) "print date$", I get a pigpio diagnostic message. "sudo apt-get upgrade pigpio" says I have the latest version.
I haven't used pi-cromite in a while; what am I doing wrong?
[code]
:~ $ sudo ./mmbasic
2020-04-01 10:50:23 gpioWrite: bad gpio (110)
2020-04-01 10:50:23 gpioSetMode: bad gpio (110)
2020-04-01 10:50:23 gpioSetPullUpDown: bad gpio (110)
print date$
^C2020-04-01 10:50:42 sigHandler: Unhandled signal 2, terminating
pigpio version=64 internals=200
micros=1 allocMode=1 dmaInitCbs=2 DMARestarts=1
samples 1 maxSamples 1300 maxEmit 0 emitFrags 0
cbTicks 71765, cbCalls 8023
pipe: good 0, short 0, would block 0
alertTicks 6384, lateTicks 0, moreToDo 1637
       7         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0         0        11       294     12183    102032    422623     98755     13439       523        30         3         1         0         0         0         0         0         0         0         1         0         0         0         0         0         0         0         0         0        18
[/code]
paulwratt
Posted: 03:27am 13 Apr 2020
just a note, the url listed in the PDF is wrong, should be abyz.me.uk
