Local Time 09:42 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Arduino Environment for PIC32
CircuitGizmos
Posted: 08:18pm 26 Apr 2019
I've had someone request to use the Arduino IDE with the CGMICROKIT. This would forgo the MMBASIC that is loaded on the chip and load it with the code developed in the Arduino IDE.
I've found that there is support for the '120, the '250, and the '270 in a board support package called chipKIT. I've tried using the IDE to make a hex file and PICKIT3 to load that hex file. I thought that one of these would work at least with some simple blinky test code. But nope.
So I tried a copy/edit of one of the boards to make a '170 flavor, but still no blinky.
Still going down a rabbit hole trying to see what I missed, but I thought I would ask here if anyone has done this.
Posted: 08:48pm 26 Apr 2019
Probably a daft question but I suspect a chipKit-specific/Arduino-specific bootloader is needed (and is probably CPU-specific).
Is one, and did you install it?
CircuitGizmos
Posted: 08:58pm 26 Apr 2019
  JohnS said   Probably a daft question but I suspect a chipKit-specific/Arduino-specific bootloader is needed (and is probably CPU-specific).
There are some ugly files that I modified that end in ".ld" that have bootloader and non-bootloader options. I modified the nobootloader file.
For example:
chipKIT-application-32MX250F128.ld
chipKIT-application-32MX250F128-nobootloader.ld
No need for bootloader if I'm using the PICKIT 3 to program. I amuse.
CircuitGizmos
Posted: 09:09pm 26 Apr 2019
I don't want the bootloader because the console pins won't be right.
Posted: 09:30pm 26 Apr 2019
You're right that you don't need a bootloader with the PICkit3 but I suspect the Arduino IDE expects the right bootloader.
Unless it can talk direct to a PICkit3, but I think not and anyway typical Arduino users would not have or want a PICkit.
vegipete
Does anything at fubarino.org help?
CircuitGizmos
Posted: 09:34pm 26 Apr 2019
  JohnS said   You're right that you don't need a bootloader with the PICkit3 but I suspect the Arduino IDE expects the right bootloader.
The Arduino IDE has an option to build a hex file that I can read using the PICKIT3 software. I'm not sure what programmer would integrate with the Arduino IDE.
CircuitGizmos
Posted: 09:37pm 26 Apr 2019
  vegipete said   Does anything at fubarino.org help?
Fubarino is a subset of the chipKIT stuff. I didn't find anything at the site.
Posted: 09:41pm 26 Apr 2019
Well... if the user will have a PICkit3 then all should be OK - though rather painful.
So... why did you need to change any .ld file? None already that targetted your board or what?
(Yes they're horrible.)
Posted: 10:08pm 26 Apr 2019
You can probably look at a few hex files that work (ones not from your new Arduino system) and compare with one that's from the Arduino system to figure what's wrong.
As you'll know, you'll need the DEVCFGn bytes with sane values.
CircuitGizmos
Posted: 11:33pm 26 Apr 2019
  JohnS said   Well... if the user will have a PICkit3 then all should be OK - though rather painful.
True that, but perhaps improvement later.
  JohnS said   So... why did you need to change any .ld file? None already that targetted your board or what?
Correct.
CircuitGizmos
Posted: 11:34pm 26 Apr 2019
  JohnS said   You can probably look at a few hex files that work (ones not from your new Arduino system) and compare with one that's from the Arduino system to figure what's wrong.
I'm sure I'm zigging when I should be zagging.
isochronic
Posted: 03:23am 27 Apr 2019
This looks similar to the cgmicrokit scenario.
Not sure if it helps but - Chipkit / Agilent sometimes use a wiki for docos, there is a recent update , worth a look
Edited by chronic 2019-04-28
Posted: 06:11am 27 Apr 2019
Sounds like the problem is in the .ld and/or that the hex file expects the matching bootloader and/or the hex is not adapted to the specific PIC32 variant. You can check the latter two by hunting around the hex. If it's wrong the .ld may well be the cause.
E.g. the hex may have no start addr or one that jumps into the bootloader you've not got.
