Local Time 08:41 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New to MMBasic
Lappa
Posted: 04:13am 05 Apr 2019
I'm very much interested in getting up to speed with MMBasic and the ARM H7 board. My previous experience with basic is Borland Turbo Basic and Microsoft Quick basic many moons ago.
I have followed a build on another forum using MMBasic and this seems to be the way to go. I have some experience with Arduino.
My question is this.:
Is there a special version of MMBasic for the H7 or do I download the generic MMBasic and use new calls to the H7 Board?
Hopefully this isn't a often asks question as I have had a search of the forum.
Posted: 04:20am 05 Apr 2019
Welcome to the forum.
The post directly below yours is worth a read.
https://www.thebackshed.com/forum/forum_posts.asp?TID=11287&PN=1
It explains the various versions and has a link to the post with the latest version for H7
Lappa
Posted: 05:14am 05 Apr 2019
Thanks. I have read that post and read the variations.
When I hit the Armmite H7 it took me to a post with a demonstration. Is the zip file above it the link you talk about? I thought it was the code for the demo.
OA47
Posted: 06:08am 05 Apr 2019
Lappa, if you look further down to the last post you should see two links, one for the MMBasic install and one for the manual.
OA47
Lappa
Posted: 06:31am 05 Apr 2019
Thanks. Got it!
Posted: 08:36am 05 Apr 2019
  Lappa said   <snip>Microsoft Quick basic
You should feel right at home. it is clear that MMBasic has implemented a lot of the common functionality from QB (and even VB) - there are some differences mainly in syntax (e.g. you can DO WHILE and LOOP UNTIL but not DO UNTIL or LOOP WHILE) but these are easily worked around. In the library I have written a few VB-like functions mainly to provide code comaptibility (with a small c) and I use them all the time... there is a speed overhead but I find they really make MMBasic an easy convert from VB
The Micromites all fall into several groups. Within a given group, the code is largely the same (there are some trips, e.g. the 144 & 100 pin MMXs use the same binary but the 64 pinner has it's own) - the code has to be compiled for the right platform so you can't get a standard fit at the binary level.
Have fun, and welcome to the forum
Lappa
Posted: 08:44am 05 Apr 2019
Thanks for the welcome and help. Thought I had an H7 in my pile but it’s an 401RE so RS gets an order on Monday.
Posted: 09:56am 05 Apr 2019
grab yourself a Nucleo board - it is a really cheap way to get into the H7 and so easy to install the firmware. Seriously, I wonder why (if all you want is a controller to interface to the outside world) you would go to the trouble of designing your own PCB etc. I have a couple of H7 projects and they use Nucleo boards un-altered... and they just do what they are supposed to. A real joy and fast as a stabbed rat
Lappa
Posted: 10:08am 05 Apr 2019
No, no,
. I’m not making a PCB, I’m just ordering a Nucleo H743Z1 board from RS
The Nucleo I already have, a F401RE, apparently is not suitable for MMBasic. Edited by Lappa 2019-04-06
KeepIS
Posted: 12:04am 06 Apr 2019
Just in case this wasn't clear: The manual in the H7 Link is the H7 hardware setup and MM.Basic code changes along with unique H7 commands. You should also download the latest Micromite and Micromite Plus manuals as the 3 are needed to cover every command.
